Thread: Seized Emergency Brake, NoIcon Displayed
Results 1 to 20 of 26
  1. #1 Seized Emergency Brake, NoIcon Displayed
    Dec 2011
    Canada
    Hey everyone,
    Yesterday I rotated my tires in my garage, but before I raised the car on stands, I put the emergency brake on for the first time since I have owned it. Its a 2001 GTP with 269,000km's on it, so it has a lot of wear on it. When I was finished, I released the e-brake and while reversing out it was fine, but when I put the car in drive, that's when you can hear and feel the e-brake grab and screech while I try to move forward. There is no e-brake icon flashing or displayed on my dashboard at all. The e-brake pedal does have some slack before it starts to get resistance when pressing down. I have no idea on what to do. This car has given me nothing but problems, I just want to scream. Hopefully someone can help me out! Thank you.
  2. #2 Re: Seized Emergency Brake, NoIcon Displayed
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Usually e-brakes are not used very often and rust. Then when the do get used they don't return to proper position. Just take off your rear wheel and rotors and check it out. There are drum style emergency brakes on the inside of your rear rotors. My guess is some with some cleaning and lubing of the cables your emergency pads will return. Once you get them free and working you may want to use them more often to keep them working. Here is a vid that show the rear brakes 2002 Pontiac Grand Prix Brake Change - YouTube
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  3. #3 Re: Seized Emergency Brake, NoIcon Displayed
    Dec 2011
    Canada
    Thank you for the reply and video link. Unfortunately when I rotated my tires, the steel rails (don't know the real name of it) that I put the jack and stands under have rusted so bad that they have warped/crumbled and moved under the weight of the car. I was nervous the whole time I switched tires. I do not believe they are safe enough to withstand the weight of the car for an even longer period of time. Basically I am now stuck having to tow this car to the shop to get them to fix it?
    Besides this brake issue I have the following problems:
    ABS and TC lights on dash-
    Power Steering seems to have gone
    Holes in resonator and both mufflers have split- quoted at $750 to repair
    Wheel bearing
    3rd gear doesn't change until the car hits 80km's! Sounds and feels like its redlining
    My key does not come out when I turn the car off, need to fish my fingers in steering colum to press release button
    list goes on......
    any one else have the amount of issues i have?
  4. #4 Re: Seized Emergency Brake, NoIcon Displayed
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    hold on a minute and ill show you a new jack point
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  5. #5 Re: Seized Emergency Brake, NoIcon Displayed
    Jul 2011
    Michigan
    jack ut up at the end of the trailing arm (end that bolts to the unibody not the hub assembly)
    #5. At the front, jack ut up where the front control arm bushing is.
  6. #6 Re: Seized Emergency Brake, NoIcon Displayed
    Ohio
    Quote Originally Posted by BlackGT97 View Post
    #5
    just in case he dont know the trailing arm is number 5
  7. #7 Re: Seized Emergency Brake, NoIcon Displayed
    Dec 2011
    Canada
    Forgot to ask, what about a good lifting spot for the front of the car?
  8. #8 Re: Seized Emergency Brake, NoIcon Displayed
    Jul 2011
    Michigan
    there ya go man
  9. #9 Re: Seized Emergency Brake, NoIcon Displayed
    Dec 2011
    Canada
    Thank you you both for that info. I will definitely try that out. Can I put a jack stand under the trailing arm or only the jack itself? Thanks again
  10. #10 Re: Seized Emergency Brake, NoIcon Displayed
    Jul 2011
    Michigan
    on my 97 there is a spot for a jack stand. looks like the frame of the car. lifting spot for front is on the same post. i can take a picture of the rear jack stand spot if needed
  11. #11 Re: Seized Emergency Brake, NoIcon Displayed
    Dec 2011
    Canada
    The pics really help
  12. #12 Re: Seized Emergency Brake, NoIcon Displayed
    Dec 2011
    Canada
    If you can that would be great. I've done some basic repairs to my car, but have never lifted a car from somewhere other than the rails. An actual picture would help me feel more secure versus a diagram
  13. #13 Re: Seized Emergency Brake, NoIcon Displayed
    Jul 2011
    Michigan
    this is the spot for the stands. its right next to the fuel filter. this is for the rear. next post will be front. this is on the other side of the car as well.
    and this is where you lift it at.
  14. #14 Re: Seized Emergency Brake, NoIcon Displayed
    Dec 2011
    Canada
    Thank you very much for your time and assistance. I have printed the pictures, will walk my dog, then get at it. Hopefully all goes well. Thank you again!
  15. #15 Re: Seized Emergency Brake, NoIcon Displayed
    Pennsylvania
    Is this photo from one of the Discovery Channel's sunken treasures shows?
  16. #16 Re: Seized Emergency Brake, NoIcon Displayed
    Jul 2011
    Michigan
    allright. give me a minute
  17. #17 Re: Seized Emergency Brake, NoIcon Displayed
    Jul 2011
    Michigan
    this is where i put the jack stands in the front. right in front of that bolt head.
    this is where i jack it up at. its the big black metal subframe part that goes across the car.
  18. #18 Re: Seized Emergency Brake, NoIcon Displayed
    Jul 2011
    Michigan
    no...just a pic of a 14 yr. old michigan DD lol.
  19. #19 Re: Seized Emergency Brake, NoIcon Displayed
    Jul 2011
    Michigan
    just read your second post. abs and trac light is from the bad wheel bearing. fairly easy and not real expensive to fix. exhaust, just put a new resonator on or glasspack (for deeper sound) find a friend wiht a weler and weld it on. get stock tips at a junk yard. doesnt even come close to $750. i dont know much about the key, but there is a solenoid that has to be replaced ( i think). It could be worse.
  20. #20 Re: Seized Emergency Brake, NoIcon Displayed
    Washington Michigan
    For the trans not shifting try doing a trans service. Drop the trans pan and replace the filter and fluid. Add a quart of Lucas trans fix (available at the auto parts store) Your car needs Dexron III trans fluid probably about 6 or 7 quarts plus the the Lucas should do ya. You can search for a pan drop or filter change on your car on you tube to see a video. I know it exists I watched it to learn myself. I had similar issue on high mileage GP and this worked great.
  1. Engine seized?
    By seanparker3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2011, 12:52 AM
  2. How To Open A Seized Door
    By Lakerman in forum General Tech Discussion
    Last Post: 01-26-2011, 09:26 AM
  3. Remount Emergency Brake
    By 96GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 12-31-2010, 09:50 PM
  4. Engine Seized
    By Green38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-09-2010, 01:33 AM
  5. Emergency brake gone
    By BlackJack in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 08:49 PM
