Thread: Tie rod noise
Results 1 to 2 of 2
  1. #1 Tie rod noise
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Hey guys. I replaced my inner and outer tie rods with Deeza ones from RockAuto. Everything went smooth, but now when I turn my wheels right or left, I get a high pitched whining noise coming from the tie rods. The noise occurs both at a stop and while I'm driving. The outer rods came with a grease zerk fitting, but I thought I read somewhere they were already greased, so I didn't add any to them. Should I? What else could cause this? Could the tie rod nuts in the knuckle be too tight?
  2. #2 Re: Tie rod noise
    grease them and see if it goes away just make sure you don't pop the rubber boot.
  1. Another f...in noise!
    By RyanL in forum Brakes/Suspension/Chassis
    Last Post: 10-11-2010, 02:47 PM
  2. GTP Noise....
    By SuperCharged0nE in forum General Tech Discussion
    Last Post: 04-02-2010, 12:01 PM
  3. New noise..again..help?
    By BwolfGT in forum General Tech Discussion
    Last Post: 11-03-2009, 09:47 PM
  4. This noise
    By pontiackid in forum General Tech Discussion
    Last Post: 06-11-2009, 11:41 AM
  5. What do you think this noise is?
    Last Post: 07-03-2008, 09:54 PM
