Thread: Best way to remove broken bolt
Results 1 to 11 of 11
  1. #1 Best way to remove broken bolt
    GTP Level Member tms8582's Avatar
    Washington Michigan
    My son's winter car (01 Grand Prix GT) has been clunking from the rear when backing down the driveway and going over curb at the bottom of the driveway. I thought it was a bad strut but after further inspection I see that the rear right control arm (the one parallel with the car) is badly cracked and about to break. I found a used one at the local junk yard and with much elbow grease got the old one off. However one of the smaller bolts broke off. Basically there are three smaller bolts that bolt the front part of the control arm to the under side of the body. I've drilled out bolts and used taps in the past but I'm wondering if there is a better tool available now days that can save me some time. I've got the car back together now and it's drivable but don't want him to drive it with only two of the three bolts for long.
    Thanks,
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  2. #2 Re: Best way to remove broken bolt
    Can I just be the first to vote JB Weld?
  3. #3 Re: Best way to remove broken bolt
    Washington Michigan
    Will that work?
  4. #4 Re: Best way to remove broken bolt
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    Sears sells a broken bolt kit that has sharp sockets to cut into the broken bolt.
    It's saved my bacon a few times.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  5. #5 Re: Best way to remove broken bolt
    Likely it's sheered off flush as I've had it happen a couple of times, right?
    Drill and tap is your best answer that I'm aware of.
  6. #6 Re: Best way to remove broken bolt
    Washington Michigan
    Yep broken off flush. I should have used a torch when it started to really get tight.
  7. #7 Re: Best way to remove broken bolt
    Enjoy drilling and tapping
  8. #8 Re: Best way to remove broken bolt
    Are you talking about the trailing arms?
  9. #9 Re: Best way to remove broken bolt
    Washington Michigan
    Yes I beleive they are called trailing arms. I didn't know when I went to the junk yard and I called it a control arm. The junk yard guy just asked me if it went parallel to the car or across. The junk yard just unbolted the bracket from the bottome of the car with the trailing arm. They said it was easier to take off and change that way. I will drill it out this weekend but I'm going to try a left handed drill bit with the first hole and heat it up first.... maybe I'll get lucky and it will come out without having to drill the full size out.
  10. #10 Re: Best way to remove broken bolt
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    They make extractors too... You drill a hole down the middle of the bolt and then the extractor is like a left hand drill bit but it's tapered and bites pretty hard. On really stubborn one's I've had about 50/50 luck with them.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  11. #11 Re: Best way to remove broken bolt
    Washington Michigan
    Quote Originally Posted by Kejross View Post
    Yeah I've used these too. I doubt it will work with as tight as it is but might be worth a try and a good set to have around for future issues.
  1. Broken throttle body bolt, help!
    By 04gtgp in forum 04+ Specifics
    Last Post: 10-29-2011, 05:03 PM
  2. Broken bolt.
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2011, 05:52 PM
  3. Broken Thermostate Bolt & small coolant leak ?!?!?
    By FlaminWhite97GTP in forum General Tech Discussion
    Last Post: 02-15-2010, 07:32 PM
  4. HELP! Can't remove crank pulley bolt!!!
    By Billy Low in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:06 PM
  5. Broken exaust manifold bolt
    By 99prixgt in forum General Tech Discussion
    Last Post: 01-18-2009, 03:14 PM
