Thread: Grinding noise when wheel turned sharply slowing down
Results 1 to 3 of 3
  1. #1 Grinding noise when wheel turned sharply slowing down
    SE Level Member steeck1's Avatar
    Dec 2011
    PA
    Occasionally my car will thump or grind that I can feel in the peddle when slowing down to a stop upon parking or whatever when the wheel is fairly sharply turned. Any idea what would cause that? Also, not sure if its linked but the ABS and trac off lights will come on and off. Thanks
  2. #2 Re: Grinding noise when wheel turned sharply slowing down
    SE Level Member Futures Passed's Avatar
    Dec 2011
    Florida
    Mine does a similar thing, but I've never felt it in the pedal. It's the tire rubbing the plastic wheel well piece (on mine, at least). If you can feel it in the pedal, though, I doubt it's what I described, because that plastic doesn't have enough strength to really slow the wheel down (which would cause that feeling in the pedal).
  3. #3 Re: Grinding noise when wheel turned sharply slowing down
    St. Louis
    Sounds like you have a wheel bearing going bad, judging by the low speed grinding sound and the fact that the ABS/Trac light is on/off at random. Jack the front end up and give the tire a wriggle left and right from the 3 and 9 o'clock position, then in/out from the 12 and 6 o'clock position. If you detect play then you have found the worn bearing.
  1. Grinding noise when going 30 and up!
    By rbrown81 in forum General Tech Discussion
    Last Post: 11-06-2011, 08:43 PM
  2. Grinding Noise
    By EJOUIE in forum General Tech Discussion
    Last Post: 10-08-2011, 11:28 AM
  3. grinding noise
    By BoostnBlackGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2011, 11:28 AM
  4. grinding noise.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 01-03-2011, 11:03 AM
  5. new grinding noise
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2010, 08:07 AM
