Trying to be brief, and thorough, so to it. Bought-gambled on-03 gtp w/ 120k mi. in July. It's pretty clean in and out, obviously serviced recently, but still seemed neglected. Also, it had been lightly modded; lights, door locks, stereo, etc. Trying to get/be smart about it, working thru all normal stuff, fluids, plugs, brakes, etc. Most things worked, but ABS/TCS lights were on when I test drove it. I gambled it was 1 or more wheel brg hubs.
So, I paid $125 & had PCM reflashed to latest factory release at dealer. All's good. Service rep is real cool. Says tech felt play in fr rt hub & suggests I start there to get ABS/TCS working.
1) why would they lift it to flash PCM??
1st hub I put on I pulled out wires from back. DA--!!!! Waste of $-no, live & learn. Remove what I just broke & install other new hub. Test drive, still no abs/tcs. Proceed to replace rest of hubs. Both fr, & rr rt are zzp, rr lt is az. Still no ABS/TCS.
Back to dealer, $125 for diagnosis. Said 3 times, "4 new hubs, need to know exactly which parts are not working". They said, its the rt rr (zzp) HUB, it reads "0", parts + labor = $826, so I went to az, & put new hub matching good hub (rr lt).
Still doesn't work.
Dealer isn't really being responsive, no comment why. They won't even suggest 2 new hubs from different makes would be bad at same corner & everything else is good. Just stinky situation.
Additionally, I've checked all fuses, disconnected battey, clear codes w/ obdII (no codes to clear-but trying it all), voltmeter @ each harness @ hubs w/ ignition "on", all 4 get 4.70 - 4.71 v
2) Is 4.7 v what they should be?
Thought, maybe rr rt was cross wired somewhere, so -rewired pigtail(?), tested, still does not work. so i put it back.
Bought $200 scanner supposed to read gm abs, put I tested it in parking lot and it had no mention or acknowledgment of any ABS, said everything was good. Returned it. No luck renting one.
ANY HELP?
IS THERE A METHOD OF TESTING HUBS WHEN NOT INSTALLED?
CAN GM DEALER/TECH II ACTUALLY IDENTIFY A WIRING ISSUE?
Differnet yrs/models vary, ANY DETAILED WIRING DIAGRAMS FOR 03 GTP?
Sorry for length.
Thanks for any help!
