Thread: Summit racing has a clearance on front cross drilled/slotted rotors
Results 1 to 14 of 14
  1. #1 Summit racing has a clearance on front cross drilled/slotted rotors
    Mullet Member Wotgtp's Avatar
    Connecticut
    Browsing the website for deals, and found this.
    3.8L/231 - GRAND PRIX - PONTIAC - 2000 - Clearance - SummitRacing.com
    I wasn't too sure if this is the right place for it (vendor section/for sale/etc.) but I figure I'd post it up. Hopefully it saves someone some money if they're looking to replace their rotors. I'd jump on it but I'm doing an impala upgrade.
  2. #2 Re: Summit racing has a clearance on front cross drilled/slotted rotors
    Out West
    Do you have links for both?
  3. #3 Re: Summit racing has a clearance on front cross drilled/slotted rotors
    Connecticut
    That was the only one that came up, but I can't think of a reason why they'd be different. Do the axles somehow effect the design of them?
  4. #4 Re: Summit racing has a clearance on front cross drilled/slotted rotors
    Out West
    They don't seem to have the left side.
    There are another set of cross drilled that are $25/ea
  5. #5 Re: Summit racing has a clearance on front cross drilled/slotted rotors
    Connecticut
    That link says it's for the rear of the drivers side.
  6. #6 Re: Summit racing has a clearance on front cross drilled/slotted rotors
    Out West
    Yeah i cant find the left side front rotor.
  7. #7 Re: Summit racing has a clearance on front cross drilled/slotted rotors
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    some rotor brands make left and right rotors, but im pretty sure those can go on both sides.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  8. #8 Re: Summit racing has a clearance on front cross drilled/slotted rotors
    utah
    The way the slots go is stricly for looks. Can't believe more people aren't jumpin on these
  9. #9 Re: Summit racing has a clearance on front cross drilled/slotted rotors
    Minnesota
    Quote Originally Posted by boostedcompg View Post
    The way the slots go is side specific. You can put these one backwards. I know because I did it. lol It's hard to explain without a picture though. The inner part of the slot should be hitting the pad first before the outer comes in. The rotors I got from "Brakemotive" off Ebay said left and right on them.
    I will try to take a picture of mine tomorrow.
  10. #10 Re: Summit racing has a clearance on front cross drilled/slotted rotors
    utah
    Ill have to dig up the thing I read on them someone took several different styles and ran them all forward and backword with little to no difference in braking performance
  11. #11 Re: Summit racing has a clearance on front cross drilled/slotted rotors
    Minnesota
    Looks like we are both vampires. lol I don't think it's so much for braking performance as it is pad wear. The wrong way and the slots basically bite into the pad causing it to wear down faster. I could be wrong though.
  12. #12 Re: Summit racing has a clearance on front cross drilled/slotted rotors
    SE Level Member Freimuth's Avatar
    Nov 2009
    Clinton, Ohio
    Guys for Summit rotors..
    SUM-DSEP-55036L
    SUM-DSEP-55036R
    Those are the fronts L for left side, R for right side
    SUM-DSEP-55039L
    SUM-DSEP-55039R
    These are the rears L for left side, R for right side
    Here is a link to more rotors.
    3.8L/231 - Brake Rotors - GRAND PRIX - PONTIAC - 1999 - SummitRacing.com
    Let me know if you have any questions.
    New to me ---- 1999 Grand Prix GTP 216K miles and counting
    SOLD----1997 Grand Prix SE 3.8 -- 1K miles from the 200k club.
  13. #13 Re: Summit racing has a clearance on front cross drilled/slotted rotors
    Out West
    dont see the lefts.
    thats why the rights are on sale. because only rights.
  14. #14 Re: Summit racing has a clearance on front cross drilled/slotted rotors
    Nov 2009
    Clinton, Ohio
    Quote Originally Posted by Nixon View Post
    dont see the lefts.
    You are correct they are being subbed over to SUM-BR-62057L.
  1. OEM Brakes or Drilled/Slotted Rotors For Winter?
    By extreme in forum Brakes/Suspension/Chassis
    Last Post: 10-16-2011, 07:48 PM
  2. cross drilled rotors
    By RyanL in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2010, 10:48 PM
  3. Used Drilled Slotted Rotors?
    By Confusingboat in forum Tires & Wheels
    Last Post: 09-23-2010, 07:20 PM
  4. Can drilled and slotted rotors be turned?
    By corsagtp in forum Brakes/Suspension/Chassis
    Last Post: 04-11-2010, 01:55 AM
  5. new back brakes. Hows the summit racing rotors?
    By mxthunder in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2009, 11:15 PM
