Thread: Best quick struts?
Results 1 to 20 of 21
  1. #1 Best quick struts?
    GTX Level Member crbquist's Avatar
    Massachusetts
    What are the best quality ready to bolt in quick struts? I replaced all my factory struts with "prime choice" auto parts quick struts last year and the rears are already failing. Sadly, I only have a little over 10K miles on them.. My front end has also made all these clunking and popping noises when turning sharp at slow speeds since installing these struts. Now I am looking to replace all four front and rear with the best quality quick strut that money can buy. Any suggestions?
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  2. #2 Re: Best quick struts?
    kyb
  3. #3 Re: Best quick struts?
    Massachusetts
    kyb
    I thought kyb didn't make a quick strut? I've looked on different sites and can only find bare struts such as the agx adjustable
  4. #4 Re: Best quick struts?
    for your car they exist.
  5. #5 Re: Best quick struts?
    Ocala, FL
    They do, search around.
    Kyb makes a quick strut for our car that uses their excel-g strut(the one that replaced the gr-2).
    Also, if you want to spend some $$.. Zzp sells a kyb agx/ssc quickstrut.
  6. #6 Re: Best quick struts?
    Massachusetts
    Quote Originally Posted by codyAK View Post
    I have heard mixed results from the AGX struts. Some say they wear out prematurely.
    Quote Originally Posted by crbquist View Post
    For that reason I avoided them.
    Quote Originally Posted by Dtrick22 View Post
    Do not get Monroe's...My car is lifted way higher than it should be. I knew new springs would raise it slightly but these make it REALLY bad, and didn't even ride that well either. If you ever see my car around town, I'm sure you'll notice...It's been a year and a half so its dropping a little but it's still way too high in the front.
    Monroes should be avoided because the KYB are of better quality.
  8. #8 Re: Best quick struts?
    Jul 2010
    upstate NY
    I put KYB GR2s on all 4 corners of my 05 GT about 20k miles ago. The rears were quick struts. The fronts were not so I re-used the front springs. They are doing great. I thought they could have been valved tighter when I first drove them (more sporty). But 20K miles later they haven't soften any noticeable amount either. So the GR2s are quality and OK for the GT suspension but I would suggest something sportier for the GTP. I would have sprung for the adjustable AGX but they are not available for the 05 GT. I heard lowered suspensions shorten the life of the struts.
    I looked into Bilsteins too but they are crazy expensive.
  9. #9 Re: Best quick struts?
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  10. #10 Re: Best quick struts?
    Bunnell, FL
    w/o sounding dumb. and drunk. quick struts?
    I'm a Sex Offender
  11. #11 Re: Best quick struts?
    all new ready to bolt in struts.
    new springs, mount plates etc
  12. #12 Re: Best quick struts?
    Massachusetts
    Anyone know the best site to purchase KYB quick struts?
  13. #13 Re: Best quick struts?
    rockauto.com is typically pretty good.
  14. #14 Re: Best quick struts?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    I have Monroe quick struts on mine and they are at stock ride height and did not raise it. I got the premium set though. All four + shipping for around $360. The car is just like it was with the stock struts before they went bad.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  15. #15 Re: Best quick struts?
    Jul 2010
    upstate NY
    I recommend Rockauto. Bought a lot of stuff from them over the years. Had a truck bearing from Rockauto start humming a week after I installed it. They sent a new one from a different supplier without hassle.
  16. #16 Re: Best quick struts?
    Massachusetts
    Quote Originally Posted by WhatNext View Post
    Rockauto does not carry KYB complete strut assemblies.
  17. #17 Re: Best quick struts?
    Yes they do...
    Front is kyb SR4002, rears are SR4003 and SR4004.
  18. #18 Re: Best quick struts?
    Massachusetts
    Yes they do...
    Weird.. Only way I could find them was to search under the part numbers. If you search directly through the parts catalog they are not listed. I could only find KYB bare struts.. Thanks though!!
  19. #19 Re: Best quick struts?
    they dont list those springs for GTP's for some odd reason.
  20. #20 Re: Best quick struts?
    GTP Level Member
    springfield IL
    ^^^^. They gave me a reason why they don't..... Let me see if I still have the email.
    Said ppl were sayn they were out quicker on the gtps or something like that...???
  1. Monroe Quick Struts Assemblies %50 Off
    By koolkeith19 in forum Brakes/Suspension/Chassis
    Last Post: 08-08-2011, 02:28 PM
  2. zzp quick struts or coil overs???
    By mikew99gse in forum Brakes/Suspension/Chassis
    Last Post: 03-08-2011, 08:39 PM
  3. Monroe Quick Struts
    By mlasnoski in forum Brakes/Suspension/Chassis
    Last Post: 03-03-2011, 07:19 AM
  4. Struts for 04 GTP
    By ionroller in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2010, 12:43 PM
  5. quick struts for 04 comp g?
    By mike81 in forum Brakes/Suspension/Chassis
    Last Post: 11-27-2009, 04:10 AM
