Thread: Wheel Alignment and car still pulls badly to the right
Results 1 to 20 of 25
  1. #1 Wheel Alignment and car still pulls badly to the right
    Donating Users Burgundyman's Avatar
    Had a wheel alignment done at dealership. Said I needed parts but should be fine for now. Car was pulling badly to the right and still does. The steering tightened but still pulls which puts a strain on the wrist. Mechanic said I should replace struts but then again, they will say anything to get you to spend. Car has 120K. Where is a good place for a wheel alignment?
    1998 Grand Prix - GTP
    RED- 4 Door Sedan
  2. #2 Re: Wheel Alignment and car still pulls badly to the right
    well what parts do you need????
    I would guess ti rods, because I bet your steering wheel in cocked to the side and the toe is far out to cause the pull.
    and screw dealerships for that stuff, find a local shop that will do it.
  3. #3 Re: Wheel Alignment and car still pulls badly to the right
    A shop that specializes in alignments, takes appointments and is booked for a week.
    Have one near me, but I doubt you're near Canada at all haha.
  4. #4 Re: Wheel Alignment and car still pulls badly to the right
    how would struts make the car pull? unless its bent or something.
    i find it hard to believe that a dealer would do an alignment and let it leave the shop pulling to one side.(did you pay for this work?) most shops will test the front end to make sure its all tight, if its got bad parts they wont do the alignment unless the parts are replaced.
    you cold have bad tie rods, bad lca's, ball joints, even a bad tire could make it pull.
  5. #5 Re: Wheel Alignment and car still pulls badly to the right
    I will take it back or better yet find a dedicated shop.
    RED- 4 Door Sedan
  6. #6 Re: Wheel Alignment and car still pulls badly to the right
    The Boss Iceman6669's Avatar
    Jun 2011
    I have had every alignment shop tell me that struts do affect your alignment. They also say that you have to have an alignment done after you change your struts.
  7. #7 Re: Wheel Alignment and car still pulls badly to the right
    Quote Originally Posted by Iceman6669 View Post
    i see that being true only if you have slotted struts,(caster and camber adjustment) mine are just 2 holes, that bolt up to the knuckle, no adjustment can me made to it. (you need to pound the bolts in too.)
  8. #8 Re: Wheel Alignment and car still pulls badly to the right
    Grand Rapids, MI
    i know that this is true. BUT every time that my struts have been off (on the GT and the GTP) the alignment was way off. how? idk. but i have a camer kit on em now anyway so it really doesn't matter. but even with the one way two bolt design it would alter the alignment.
  9. #9 Re: Wheel Alignment and car still pulls badly to the right
    Portland Oregon
    My GS does the same thing. I've literally replaced almost everything in the front end. Only things I haven't touched are axles, bearings, and struts, and it still pulls right.
  10. #10 Re: Wheel Alignment and car still pulls badly to the right
    Quote Originally Posted by OH4CompG View Post
    This is also my worry and advised by mechanic.
    RED- 4 Door Sedan
  11. #11 Re: Wheel Alignment and car still pulls badly to the right
    Jul 2010
    upstate NY
    It could be a tire gone bad. An easy and quick check is to swap the front tires (left to right). If after the swap, it pulls the other way then its the tire.
  12. #12 Re: Wheel Alignment and car still pulls badly to the right
    Quote Originally Posted by WhatNext View Post
    I rotate the tires regularly...this is my last rotation before a new set installed around December.
    RED- 4 Door Sedan
  13. #13 Re: Wheel Alignment and car still pulls badly to the right
    GTX Level Member f3racer's Avatar
    dongducheon, south korea
    had the same issue in my explorer. it turned out that the brakes needed to be bled. the right front caliper was dragging causing constant friction against the rotor.
    SSG US Army Military Police
    2006 Grand Prix GXP
    http://gmls4.com
  14. #14 Re: Wheel Alignment and car still pulls badly to the right
    Waukesha, WI
    try swapping tires? did they even check air preasure?
    did you get spec #s from the alignment?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  15. #15 Re: Wheel Alignment and car still pulls badly to the right
    Quote Originally Posted by redlinepontiac View Post
    Air pressure is good. I had recently rotated tires front to back, I could swap left front with right front.
    RED- 4 Door Sedan
  16. #16 Re: Wheel Alignment and car still pulls badly to the right
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    theres a bearing that the coil sits on, on the strut assembly. they get dirt in it and get worn out. does your car pull ONLY to the right? test this out, at a complete stop. turn the wheel all the way to the left ( probably dosent need to be all the way), then straighten it AS YOU accelerate. after that, if it feels like its not pulling as hard to the right, or is even going straight, the bearing im talking about is bad (not sure of the name)
  17. #17 Re: Wheel Alignment and car still pulls badly to the right
    Quote Originally Posted by jpmiller View Post
    will give this a try. Yes, it pulls only to the right. Does anyone know what this bearing is called?
    RED- 4 Door Sedan
  18. #18 Re: Wheel Alignment and car still pulls badly to the right
    i would assume your talking about the strut mount.
  19. #19 Re: Wheel Alignment and car still pulls badly to the right
    Jul 2011
    Michigan
    the part im talking about is called "the spring seat with pivot bearing" in the picture.
  20. #20 Re: Wheel Alignment and car still pulls badly to the right
    Cool. Thanks. Will see if I can get this part to fix the problem.
    RED- 4 Door Sedan
  1. Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:05 PM
  2. Wheel Alignment??
    By apierce1289 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2011, 10:09 PM
  3. 2nd gear pulls...
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 12-31-2010, 11:01 PM
  4. Wheel alignment
    By kissmyss in forum General Tech Discussion
    Last Post: 04-19-2010, 12:13 PM
  5. What kind of wheel alignment do I need?
    By 04CompG in forum General Tech Discussion
    Last Post: 03-22-2009, 11:23 PM
