There making noise because i need new ones. I know that and yes they are long over due! The other concern I am having is the noise/sound either goes away or changes when I turn the wheels while driving.Now if i am thinking about this correctly that should not happen enless i have a bad wheel bearing or something to where there would be play in the wheel. After i did my tranny and cam swap,the brakes started wearing real bad around the outside of the rotor. That may be because of the pad comming apart or....another problem that im trying to figure out....so thats what im wondering, if there is another problem.
I checked the hub nut last night and everything was tight. Another thing is it sounds like the brakes on that wheel are always engauged. I can hear them scraping going down the road all the time. But again if im thinking about this right there should be no play between the brake disk and the brake caliper once the wheel and everything is bolted on correct? So are they making different sounds when im moving and i turn the wheel???? I just dont want to mess up a brand new set of rotors and pads due to another problem. Thanks fellas
You can see here that the inner part of the rotor has about a half of an inch left that looks ok. Now the outer as you can see is very worn. Again im just making sure i dont have a problem i dont know about.
