Thread: *Sigh* Brake Light Turned On Today, Need Some Help
Results 1 to 20 of 20
  1. #1 *Sigh* Brake Light Turned On Today, Need Some Help
    Jun 2011
    Detroit, MI
    Ok so today I was driving my car and I just randomly noticed the brake light was on, with the exclamation point and parking "P" both illuminated. I'm not sure why they went on but here are the only things I can think of that might have influenced it:
    1. Yesterday I sprayed wheel and tire cleaner all around my wheels and tires (duh) but I got some on the rotors and possibly brakes.
    2. When I got in the car for the first time today I kind of was stretching and I pushed the brake pedal down all the way for some stupid reason. I heard something but it was at the same time as when I shifted into reverse, so I don't know if the sound had anything to do with the brake lines or anything.
    It is definitely is not harder to push on the brake pedal. And to tell you the truth, I can't really tell if you have to press on the brake more to come to a stop than normally.
    I checked for leaks, didn't see any drips or puddles. Checked the brake fluid level, it seems normal.
    I engaged and disengaged the parking brake multiple times to make sure that wasn't setting it off for some reason.
    Please help! I know I shouldn't have been driving with the light on but my brakes seem fine, I'm just really paranoid. Should I go to the mechanic tomorrow? Rarrrr what should I look for?
    Thanks for reading
    iLoveSpade
  2. #2 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    maybe the brake light switch or what ever it is called died
  3. #3 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    on all the time or only when pressing the pedal?
  4. #4 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    Jun 2011
    Detroit, MI
    its on all the time
    iLoveSpade
  5. #5 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    Same thing happened to my car about 3 days ago. I have no idea why
  6. #6 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    Jun 2011
    Detroit, MI
    Well I checked this morning and the fluid is obviously lower. There is a wet spot under the fuel filter area and right in front of the fuel filter... time to take it in!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    God dang it! Anyone know how much this is probably going to cost?
    iLoveSpade
  7. #7 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    Jun 2011
    Detroit, MI
    are there any write ups anyone knws about on this?
    iLoveSpade
  8. #8 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    SE Level Member kentpappy's Avatar
    Nebraska
    I just took a full set of lines off of my parts car......
    2000 ZX12r (Big bore kit, Cam, 6" Extension )
    1999 Escort ZX2 (DD)
  9. #9 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    Jun 2011
    Detroit, MI
    thats one way to do it but that doesnt help me...
    iLoveSpade
  10. #10 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    Nebraska
    Quote Originally Posted by Hippo Machine View Post
    You want, I sell you
  11. #11 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    Jun 2011
    Detroit, MI
    Quote Originally Posted by kentpappy View Post
    No thanks.
    And I know how fast its leaking, the reservoir is almost empty, i will change line today.
    iLoveSpade
  12. #12 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    just fill it with fluid and see how fast it's leaking. If it's not leaking out in a week or so you can get by with it for a while.
  13. #13 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    Never Never Land
    Till it blows the line completely and he has no brakes at all...
  14. #14 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    Jun 2011
    Detroit, MI
    Ok so my dad thinks it might have something to do with the fuel filter I just had changed, because the leak is right by the fuel filter. Maybe the mechanic did something? Idk...
    Would it be best to change the whole hard line? Is it possible to do that? I just don't want it to happen again.
    iLoveSpade
  15. #15 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    Aug 2011
    North Jersey
    did you check that propotioning valve (i think that's the name)? its a cylinder looking part on the rear brake lines. mine started leaking a while back and it cause the light to come on my dash too.
  16. #16 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    Jun 2011
    Detroit, MI
    There is just a leak somewhere idk, I'm fixing it friday
    iLoveSpade
  17. #17 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    Aug 2011
    North Jersey
    yeah look under there. If i can, I'll try to snap a pic of what I'm referring to.
  18. #18 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    check under the master cylinder, you may have blow it out when you stood on the pedal for no reason.
    you can also cut the line where its cracked, if its cracked that is, cut it, and slap a compression fitting on it and be done with it, if its in a straight area, if its in a bend you can buy a short piece of tubing and bend it to fit, and use compression fittings on both side where you cut out the old brake line out.
    did this repair in a parts store parking lot one winter when i blew a line, they had everything i needed to fix it, pipe bender, pipe, and compression fittings. i hit the guy in front of me, right in front of a parts store, how lucky is that?
  19. #19 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    Jun 2011
    Detroit, MI
    FIXED! Bled like 100 times, but still feels soft compared to newer cars, but whatevar
    iLoveSpade
  20. #20 Re: *Sigh* Brake Light Turned On Today, Need Some Help
    if you got the abs lines all over the one side of the master cylinder, look around for 2 bleeders on it, they face the front of the car. bleed them, if you have them just like a caliper, pump, pump pump, hold, open bleeder, shut, repeat.
  1. Check Engine light came on today with 4 codes.
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2011, 12:12 AM
  2. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  3. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  4. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
  5. Third Brake Light & LED's
    By Metallistar in forum Audio, Security & Visual Electronics
    Last Post: 05-29-2009, 11:06 PM
