Thread: Allignment all messed up
Results 1 to 6 of 6
  1. #1 Allignment all messed up
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    so i got my car aligned for 100$ and it was so nice to drive, then my car started getting so bumpy i thought i had a flat. i checked my tire pressure, than my lug nuts. and the front right tire nuts were hand tight. i tightened them and they were getting loose again.. i took the tire off and saw my sway bar broke in half on the right side. i replaced the bar and now my car isn't aligned. i didn't think the sway bar made the car so different, and its so bumpy again. i hate firestone, it happened the day after i brought it to them, and i will never win the argument.
    any ideas why my car isn't aligned anymore after this install? thanks guys
  2. #2 Re: Allignment all messed up
    bolted the sway bar down on one side first, then the other?
  3. #3 Re: Allignment all messed up
    Sway isn't an item that can change the alignment.
    don't argue.. go back and ask.
  4. #4 Re: Allignment all messed up
    yeah i tightened one side first than the other, you think i could have tightened one side a bit more? because i think i might have
  5. #5 Re: Allignment all messed up
    CT
    "i checked my tire pressure, than my lug nuts. and the front right tire nuts were hand tight. i tightened them and they were getting loose again.."
    Explain that a little more because I don't quite understand what you mean.
    2001 GTP - 3.4" pulley, Headers, welded in flowmaster mufflers, Tune, Intake, SSC/AGX, Engine/Trans mount spacers, GMPP F/R Swaybar, 17" Rims, Built trans: 3.29 gears, 2500 stall, ect ect (built by Billboost)
  6. #6 Re: Allignment all messed up
    i dont really know how to explain more, i guess since all that was helping me turn was the tie rods. and the sway bar was not connected my car was having unbelievable shaking and somehow it made the lug nuts loose 2 times. it just really suxs that i paid for an alignment and now its not aligned anymore.
  1. messed up engine
    By 1998 problem child in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-11-2011, 02:11 AM
  2. New PCM? I messed up!
    By Workshop in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-22-2011, 06:42 AM
  3. Wiring all messed up...
    By Maloro619 in forum General Tech Discussion
    Last Post: 10-19-2010, 10:13 PM
  4. Seems kinda messed up huh?
    By real diehl in forum Off Topic Discussion
    Last Post: 07-25-2010, 12:42 AM
  5. I messed up! Can it be fixed???
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 04-23-2010, 03:24 AM
