check your fuse box for a blown fuse, the lights should get twice as bright when you hit the brakes if the tail lights are on when dark,(both sides) if the fuses are good check the bulbs.
another question, are you directional's blinking double fast? if so its the bulbs or maybe a flasher is dead.
and another, do the brake lights work when the head lights are not on?
