Thread: what other struts can i run on my 98 gp
Results 1 to 20 of 22
  1. #1 what other struts can i run on my 98 gp
    GT Level Member nicks98gtp's Avatar
    michigan
    im looking at a set of 04 comp g springs on craigslist locally but im not sure if they would be the same as the ones im running now? or the mount plates for the new impalas, or malibus, etc. ive noticed the newer gps, impalas, malibus,e tc have a nicer softer ride so i was curious if i could bolt up a set of these to soften up my ride a little? or if anyone has any input as to what i could throw in to make it a little more enjoyable ride
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  2. #2 Re: what other struts can i run on my 98 gp
    Omaha, NE
    97-03 fronts are different from the 04+, but rears are the same.
    I would order GR2s from ZZP or WBS.
  3. #3 Re: what other struts can i run on my 98 gp
    You can run anything.
    Its the 04/05 guys who HAVE to run struts specific to their cars.
    Also, if they are used springs.... Skip 'em.
  4. #4 Re: what other struts can i run on my 98 gp
    michigan
    my only issue is i cant poull part numbers for the new strut mount plates to see if the studs are the same spacing. the part that bolts to the knuckle looks the same on all of them but the mount on the top is my issue
  5. #5 Re: what other struts can i run on my 98 gp
    michigan
    and i guess im not as concerned with "softening" the ride but i just replaced my factory fromt struts with new mounts, and reused the old springs, and still feels like a really harsh ride. my open house is in three days so im gonna have some money to play with, im trying to find a better suspension/steering combo i guess
  6. #6 Re: what other struts can i run on my 98 gp
    GT Level Member jmoore4294's Avatar
    Quote Originally Posted by nicks98gtp View Post
    All 97-08 Grand Prixs use the exact same strut mount. Front and rear.
    2004 Pontiac Grand Prix GT2 -Wizaired-DHP Tune-180° Thermostat-GMPP STB w/brackets F/R-Bilstein HD Struts w/SSC-Projector Retro-Black SPO Grilles and Spoiler-ZZP Volt. Booster & Alt Rewire
  7. #7 Re: what other struts can i run on my 98 gp
    You can use those struts. No problem. They will bolt right up. But it won't "soften" it up. CompG struts are stiffer than your average wbody strut.
  8. #8 Re: what other struts can i run on my 98 gp
    you want soft ride?
    buy monroe quick struts.
    Not comp G stuff....
    Thats all "sporty" and will be "harsh".
  9. #9 Re: what other struts can i run on my 98 gp
    utah
    Comp G struts ride harsh when compared to the gtp setups...if you want soft and comfy look elsewhere
  10. #10 Re: what other struts can i run on my 98 gp
    michigan
    thanks for all the responses guys. i guess my next questions is (im not really that involved in the steering and suspension stuff yet) is that if i do end up goign with the comp g setup will it show any noticeable gains in handling over the gtp setup?
  11. #11 Re: what other struts can i run on my 98 gp
    probably.
    especially if the comp g stuff is new and yours is not.
  12. #12 Re: what other struts can i run on my 98 gp
    michigan
    like i said i replaced front struts and mounts, backs are completely gone and i need all new front end stuff. coming into money this weekend so its either all or nothing. any suggestions as to the best places/brands for tie rods/ball joints/control arm bushings/etc
  13. #13 Re: what other struts can i run on my 98 gp
    utah
    You'll notice it
  14. #14 Re: what other struts can i run on my 98 gp
    moog for all of the steering components.
    new LCA's, sway bar bushings, links, tie rods.
    KYB for the strut mounts and isolators and bellows etc.
    Should be nice.
  15. #15 Re: what other struts can i run on my 98 gp
    michigan
    i almost forgot about that too, sway bar is broke in half on both ends as well so itll be replaced. i see wbody store has one, and theres a couple other, is there really that much of a difference for the gm ones of the slp bars for the cost difference
  16. #16 Re: what other struts can i run on my 98 gp
    Buy a dorman sway bar.
    But buy moog end links and sway bar bushings for it.
  17. #17 Re: what other struts can i run on my 98 gp
    michigan
    thanks for all the help guys. i cant wait to get rid of this ridiculous torque steer.
  18. #18 Re: what other struts can i run on my 98 gp
    Uhhhhhhhhhh........................
    It ain't going nowhere haha.
  19. #19 Re: what other struts can i run on my 98 gp
    michigan
    its gotta get somewhat better, i got about 1/2" each way in play with tie rods, same with ball joints, c/a bushings have 126k on them, sway bar is broke on both ends. when it kicks down to pass its a little scary haha
  20. #20 Re: what other struts can i run on my 98 gp
    New suspension and struts ain't helping that noise...
  1. Struts for 04 GTP
    By ionroller in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2010, 12:43 PM
  2. Need new struts
    By Will5600 in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2010, 11:01 AM
  3. struts
    By rharper33 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 12:17 AM
  4. Struts!!!!
    By MizzBecca in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2009, 11:52 AM
