So I put my car up on the jacks today to take a look at a few things, one was a grinding which I thought might be the wheel bearing but ended up being a shield dragging on the rotor. Thing left a nice little groove but nothing that bad. While I was under there I was taking a look into a clunk I had been feeling. If I had my foot on the brake and I turn the wheel side to side I could feel it in the brakes and my passenger could feel it in his feet as well. The steering felt a bit loose, almost like a dead spot when going straight. I was looking at the power steering pump reservoir and noticed fluid on it and looks like it had leaked a bit. I checked the fluid and it was down a bit and said to add some so I'm doing that but I also cleaned off the area with brake cleaner as I couldn't tell exactly where the fluid was coming from. Now I also took the belt off so I could check the pulley and it has a bit of play in and out, should it have anything like that? Let me know if there is anything else I should check, or if you know what that damn clunk is from!
