Thread: noise on drivers side
Results 1 to 5 of 5
  1. #1 noise on drivers side
    SE Level Member 2005GrandPrix's Avatar
    Pittsburgh, Pa
    05 grand prix making a roaring sound only going down highway when changing lanes to the right wont make the noise when u turn left.
    wheel bearing or tires or is it something else??
  2. #2 Re: noise on drivers side
    GT Level Member Tea Time's Avatar
    New Brunswick
    shake ur wheel back & forth from the side if the car....does it feel loose? if so - wheel bearing.
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  3. #3 Re: noise on drivers side
    Las Vegas
    Wheel bearing for sure. I am on my second one now. Pretty common. Crappy thing is the hub bolts are loc-tited in there. what a pita. Oh and usually it is the wheel bearing on the opposite side of the direction you are turning. If the sound only happens when turning right, then the left bearing is bad. Good idea to do them both though.
  4. #4 Re: noise on drivers side
    Pittsburgh, Pa
    well did them both makes no sense at all and still makes the same noise.
  5. #5 Re: noise on drivers side
    Pittsburgh, Pa
    fixed it was the drivers side rear bearing
  1. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  2. crunching noise in front drivers side
    By tstaller2005 in forum General Tech Discussion
    Last Post: 05-01-2011, 11:13 PM
  3. Drivers Side Cooling fan making bad vibrating noise
    By WkDcLwNz in forum 5.3L V8 (LS4)
    Last Post: 02-19-2011, 10:22 AM
  4. front end squeaking/metallic noise on drivers side
    By bonerjamz03 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 07:36 PM
  5. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
