Thread: what else should be replaced?
Results 1 to 7 of 7
Threaded View
  1. #1 what else should be replaced?
    SE Level Member meoneal's Avatar
    Apr 2011
    Mendota VA
    The GP didnt pass Virginia State inspection. The shop stated that both the inner Tie Rods need to be replaced. So I found Mevotech Tie Rod ends from Partsgeek.com but Im also wondering if there might be something else that the mechanic should replace while he's at it? The GP has about 141k miles on it. As far as I know, all suspension is orig. I do know that there is a wheel bearing that is going out (abs light, trac light are on, and sounds like im riding on snow tires), but difficult to know which wheel bearing is the problem. Im old and the hearing isnt as great any more LoL
    Any suggestions on a part that the mechanic should replace while he's at the inner tie rod?
  1. Replaced hub. Now have problem.
    By twoleos617 in forum General Tech Discussion
    Last Post: 11-02-2011, 01:16 PM
  2. Replaced blower motor, still nothing. HELP PLEASE!!!
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 07-18-2010, 01:04 PM
  3. Replaced hub car still humming
    By Cbierniat24 in forum General Tech Discussion
    Last Post: 04-27-2010, 10:28 PM
  4. Replaced speakers, need opinion on amp???
    By nikkigpgt00 in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2010, 12:10 PM
  5. I replaced the Oxyg sensor now what
    By lfernes in forum General Tech Discussion
    Last Post: 11-30-2009, 08:45 AM
