Thread: Alignment Question
Results 1 to 4 of 4
  1. #1 Alignment Question
    Feb 2010
    St. Louis
    I'm going to install 4 new GR-2's on my 06 GP next weekend. I plan to re-use all of the existing isolators, pads, springs, etc, except that I will have new strut mounts. My question is: Do I need to install camber bolts while I'm installing the struts for when I go to get a 4-wheel alignment? Keep in mind that it is not being lowered. I'm sticking with the stock springs as they are in good shape (no rust or ass sag).
    TIA
  2. #2 Re: Alignment Question
    I pretty sure that the allignment shop can get the car within spec with the parts you are gunna use. Camber bolts are not really needed.
  3. #3 Re: Alignment Question
    Let me be frank and say.... most guys don't do much for an alignment....
    they get your toe in spec and call it a day.
    Unless of course your camber is 0.5* or more off. But by that I mean lets say the range is 0.9 to 1.6 and the ideal is 1.2.
    They wont really be concerned until you're around 1.8-2.0.
    Depends on the tech.
    If you want it precise then install the bolts and find a shop that specializes in alignments.
  4. #4 Re: Alignment Question
    Feb 2010
    St. Louis
    Thanks, those were the answers that I wanted to hear. I really didn't think they would be necessary with such a slight change in the suspension dynamics and stock ride height.
  1. Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:05 PM
  2. Alignment
    By dsh1106 in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2011, 10:39 AM
  3. Alignment
    By matt5112 in forum Brakes/Suspension/Chassis
    Last Post: 11-13-2010, 03:51 AM
  4. Wheel alignment
    By kissmyss in forum General Tech Discussion
    Last Post: 04-19-2010, 12:13 PM
  5. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
