Thread: SSC or Eibach?
Results 1 to 7 of 7
  1. #1 SSC or Eibach?
    May 2011
    Kansas City
    im looking into some lowering springs and was wondering which ones were better w/ Gabriel Struts from autozone? reason i ask is because i can afford either spring but cant afford the adjustable KYB struts
    Reptile Tune (SOLD)
  2. #2 Re: SSC or Eibach?
    i heard ssc are better, thoes are the ones ive been looking in to and b-g from the wbs, but im not lowered(let), so i have no clue what im talking about
    SMGPFC Member #10
  3. #3 Re: SSC or Eibach?
    Donating User Odi's Avatar
    Chicago South Suburbs
    Quote Originally Posted by SerenityGTP View Post
    idk about running lowering springs on those struts. just like any wbody strut, gabriels will be prone to shorter lifespan.
    going back to the springs tho, it really depends on your drop. ssc's tend to have even drop w/ no ass sag (iirc its 1.5in), eibachs lower nice and low and a tiny bit more in the front. (iirc 2.0in or so).
  4. #4 Re: SSC or Eibach?
    based on spring specs and the fact that eibach are progressive springs, eibachs should technically ride better in comparison to the linear springs that SSC are. they will also be lower. so long as your bump stops are trimmed accordingly they are a better all around spring for LOWERING. SSC will be better for performance. they are a linear spring and have higher spring rates.
  5. #5 Re: SSC or Eibach?
    GTX Level Member real diehl's Avatar
    Salina, KS
    If you want it to look lowered, go with B&G or Eibach...either give plenty of drop.
    I chose Springtechs. From my measurements they lowered the rear a little over an inch and the fronts about 1.75 in.
    Riding on stock struts, they aren't terrible. I would get GR2s anyway, they'll probably be cheaper than the parts store struts for a set. I'll probably get some after I get some other stuff figured out. Cut the front bumpstop/isolator down about an inch though, and get new strut mounts.
    Also, leave some money in your budget to leave room for other little suspension things that may be worn. I ended up replacing three wheel bearing/hub assemblies, both tie rod ends, sway bars and end links, strut mounts, now ball joints, and trailing arms. These cars are getting up there in age now and these things do wear out.
    signature removed for inappropriate content.
    -bio
  6. #6 Re: SSC or Eibach?
    GTP Level Member AjL227's Avatar
    IL
    I installed SSC springs with KYB GR-2's late last month. Here is a photoshoot I took on May 1st, giving you lots of angles of the spring stance after ~1-1.5k miles passed.
    http://www.grandprixforums.net/ajl22...1-a-46075.html
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  7. #7 Re: SSC or Eibach?
    FWIW I think Four Sixer is looking to sell a set of Ebaichs as soon as he can get a set of Vogtlands
  1. Eibach Pro-Kit Springs
    By mikedozz in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2011, 12:10 PM
  2. Are your springs Eibach?
    By JoshsGTP in forum Brakes/Suspension/Chassis
    Last Post: 03-02-2011, 08:43 PM
  3. eibach springs
    By timmysgtp in forum Brakes/Suspension/Chassis
    Last Post: 08-24-2010, 02:37 PM
  4. eibach pro kit or ssc gen II
    By gotboost3 in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2009, 08:56 PM
  5. Eibach Pro Kit on 2004 gp?
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 01-28-2009, 03:02 PM
