Thread: Are your springs Eibach?
Results 1 to 20 of 23
  1. #1 Are your springs Eibach?
    Akron Ohio
    I want to lower my car here soon, I was wondering if your car shook after you lowered it Because of the axle angle, and what you did to make it stop?
  2. #2 Re: Are your springs Eibach?
    Portland Oregon
    Yes, it shook a bunch after lowering. I have an 04 though. The eibach's lower the 04+ a little more than the older GP's. I added 1/4" spacers to the motor mounts and it helped but it's not all gone. I need shorter dogbones to fix it though
  3. #3 Re: Are your springs Eibach?
    yes mine did.
    i corrected it with shorter dog bones. if i were to do it again i would put spacers in to bring the motor back up.
  4. #4 Re: Are your springs Eibach?
    Akron Ohio
    Link to spacers, Please.
  5. #5 Re: Are your springs Eibach?
    http://www.grandprixforums.net/motor...tock-1107.html
    you can also make your own. its just a plate with a couple holes in it. they go under the motor mounts to raise the motor/trans back up.
  6. #6 Re: Are your springs Eibach?
    oxnard
    what are dogbones?
  7. #7 Re: Are your springs Eibach?
    MA
    Quote Originally Posted by mooretv07 View Post
    what are dogbones?
    if you open your hood and look directly down.. thats them
    they are the front mounts that go from the block to the frame directly above the radiator.
    SMGPFC Member #9
  8. #8 Re: Are your springs Eibach?
    MA
    and BTW welcome.
    SMGPFC Member #9
  9. #9 Re: Are your springs Eibach?
    oxnard
    Having trouble finding shorter dog bones for my 04. Any suggestions on where I can find some?
  10. #10 Re: Are your springs Eibach?
    Omaha, NE
    ZZP has them.
  11. #11 Re: Are your springs Eibach?
    why do you want them?
    ZZP ones are from a montana mini van, and are approximately 1" shorter than our stock ones. that is too short and you only want 3/4" shorter so you're best off modifying the stock ones.
  12. #12 Re: Are your springs Eibach?
    Texas
    I have Eibachs on my 97 and have no issues with what you are talking about. An alignment was done. The car drives nicely.
    I have stock dogbones with Rubber bushings and have some heavy ass 18's.
    Do you have poly motor mouts?
    85 Corvette
    01 TA
    03 Z06
  13. #13 Re: Are your springs Eibach?
    GTX Level Member real diehl's Avatar
    Salina, KS
    My car shook violently under any acceleration after I lowered it. I tried shorter dogbones and it did nothing. My Pass. side halfshaft was bad. Jack it up and check for play.
    This could solve most if not all of your problems.
    signature removed for inappropriate content.
    -bio
  14. #14 Re: Are your springs Eibach?
    Texas
    Quote Originally Posted by realdiehl View Post
    Have you tried cradle spacers?
    You guys having vibration issues how is you tranny and lower engine mount?
    85 Corvette
    01 TA
    03 Z06
  15. #15 Re: Are your springs Eibach?
    Quote Originally Posted by txslow6 View Post
    wbody store said this at one time too. most of the lowering vibration they experiences was due to worn motor mounts and after they were changed most was alleviated if not all of it. however, i speak from experience that bringing the motor back up to where it is supposed to be after lowering makes a difference in how the car handles and vibrates.
    as far as the cradle spacers, that is the opposite of what you want to do. cradle spacers will lower the motor so you have more clearance for an intercooler. motor mount spacers are what you do want and will raise the motor back up, essentially correcting axle geometry, but losing some clearance from the motor to the hood.
  16. #16 Re: Are your springs Eibach?
    in other words lowering is not for intercooler people.
    unless you wanted to do a short stack.
  17. #17 Re: Are your springs Eibach?
    oxnard
    I haven't lowered it yet, so I don't know if its going to vibrate or not. Looking to do all that I can to solve the problem of lowering an 04 before the issues begin. Changing out my shocks now, then will be able to look for problems
  18. #18 Re: Are your springs Eibach?
    Salina, KS
    Well after replacing both halfshafts, the vibration was barely noticeable. I'm not going to buy engine spacers either. I'll live with the little amount of vibration I have
    -bio
  19. #19 Re: Are your springs Eibach?
    Dec 2008
    Lawndale, CA
    Vinnies spacers are worth the investment if you are going lower than 1".
  20. #20 Re: Are your springs Eibach?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Highley reccomend not going with shorter dogbones, but adjustable turnbuckles instead.
    They are adjustable, soild and about 3 lbs lighter than dogbones. plus it cost a whopping $10 at lowe's
  1. eibach springs
    By timmysgtp in forum Brakes/Suspension/Chassis
    Last Post: 08-24-2010, 02:37 PM
