Thread: Front control arm
Results 1 to 7 of 7
  1. #1 Front control arm
    Apr 2009
    Madison, WI
    So I think I'll be replacing the front control arms. The front is starting to get quite "creaky". A little squirt of WD 40 on the bushings quieted the problem for about a week. The Dorman units are about $38 each on Rock Auto so I'm thinking I'll go that route. Has anyone else done this? It appears relatively simple. Did you need an alignment when you were done? Thanks.
    Oh yeah...It's an 07 GT.
  2. #2 Re: Front control arm
    complete arms are the best option.
    you get new bushings, new ball joint and an easier install.
  3. #3 Re: Front control arm
    In the W body world...who hasn't done it?
  4. #4 Re: Front control arm
    Apr 2009
    Madison, WI
    Soo....alignment?? In theory all the measurements should be the same so it shouldn't need it but I'm wondering about those who have done this. Did you do an alignment?
    It's my daily driver and only car so I need to be able to have everything planned out. I suppose I could make an appointment for an alignment and cancel it if the cars feels tight and goes straight down the road.
  5. #5 Re: Front control arm
    Even if the car feels tight and goes straight..the alignment can be off. Which will wear tires etc.
    Your last alignment wasn't on the new control arms. What if one bushing was squished on little way? I know..I suck, but I'm saving your tires and making your car drive better.
  6. #6 Re: Front control arm
    Apr 2009
    Madison, WI
    That's pretty much what I was thinking too. Just wanted to hear it from someone else. Thanks.
  1. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  2. front control arm bushing
    By Jakegday in forum General Tech Discussion
    Last Post: 10-26-2010, 12:36 PM
  3. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  4. Changed front rt control arm and now it wont start
    By AREED in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2010, 09:31 PM
  5. Front Control Arm Bushings
    By 2001camaroB4C in forum Brakes/Suspension/Chassis
    Last Post: 11-23-2008, 01:38 PM
