Thread: Parking Brake Issue ?
Results 1 to 2 of 2
  1. #1 Parking Brake Issue ?
    SE Level Member DC1263's Avatar
    Nov 2008
    Middlesex, NC
    I'm having an issue with my Parking Brake...
    Up until recently when I applied the brake it would hold the car, now it doesn't, so I went back there to check and see what was going on, it seems the brakes was a little frozen, On the 2006 GP the parking brake mechanism is integrated into the caliper which engages the pads, so that there is not a third set of shoes inside a/the drum, When PB is applied there is a cable that pulls on a shaft that rotates and engages the pads, then there is a torsion spring there which is supposed to return the brake to neutral when the brake is releaased, but it doesn't. I had to manually turn the shaft back to the dissengaged position to release the brake, I did that a couple of times and it seemed to loosen things up a bit but still does not return completely by spring tension,. So messing around with it a little I got the brake to hold the car, but once the brakes are/were engaged the rotation does not return /release by spring tension, , it will release some but not fully.
    There is a torsion spring and a bracket that holds the cable and a bolt under the spring
    Question : Can I take that Parking Brake Mechanism apart and clean it out and lube it up without messing with the rest of the caliper? or will that be a can of worms? Don't really need it all that much so I am not ready to purchase 2 new / re-man calipers.
    Its like that on both sides, poor design if they are both frozen like that on a car that's only 4 years old
    "The First Step In Successful Troubleshooting Is Eliminating The User As The Source Of The Problem"
    2006_Grand Prix_Liquid Silver Metallic_Black Leather_3.8_192,000
  2. #2 Re: Parking Brake Issue ?
    Oct 2011
    San Antonio
    Did you ever find resolution on this? I'm trying to fix mine to now avail
  1. ???tighten parking brake????
    By gman2000watts in forum Brakes/Suspension/Chassis
    Last Post: 10-09-2010, 11:17 AM
  2. parking brake adjustment
    By CMURDAx in forum General Tech Discussion
    Last Post: 12-29-2009, 08:04 AM
  3. One-way Parking Brake on my 2008 GXP
    By jason55 in forum 5.3L V8 (LS4)
    Last Post: 07-26-2009, 09:29 AM
  4. Parking brake adjustment
    By ROTTMAN in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 10:35 PM
  5. parking brake broke
    By ionroller in forum General Tech Discussion
    Last Post: 01-03-2009, 11:10 AM
