Thread: trouble replacing hub assembly
Results 1 to 2 of 2
  1. #1 trouble replacing hub assembly
    SE Level Member andante147's Avatar
    Winfield, IL (DuPage)
    hey, forum - stuck in the middle of a repair and need some advice before the rain starts! doing a front hub assembly.. put it on the spindle once and it didn't go all the way on so I figure it would push on when I tightened everything down.
    but it didn't - just forced the CV axle all weird, so I had to rent a puller to get the new hub off and start over
    first - there are some slight nics on the grooves on the new hub... trash it or not? PLus some dings where I tried to hammer it off...
    then ... how to get the hub on correctly (with this one or if I go buy another one) the one I bought doesn't seem to just slide on there.
  2. #2 Re: trouble replacing hub assembly
    I just did a wheel bearing last night and when I pulled the old out part of it stayed behind. Think it ended up coming out in three pieces. I had pulled the cv shaft though so that might have made it easier.
  1. Are these symptoms of a bad hub assembly?
    By nawarkk in forum General Tech Discussion
    Last Post: 02-18-2010, 09:28 PM
  2. How to install a Hub Assembly
    By packerfanjc in forum Tires & Wheels
    Last Post: 08-25-2009, 06:31 PM
