Thread: The Official what you need and how-to for CTS-V brakes
Page 12 of 31 FirstFirst ... 2101112131422 ... LastLast
Results 221 to 240 of 609
  1. #1 Re: The Official what you need and how-to for CTS-V brakes
    I live here. TLSheff's Avatar
    ...brain fart.
    <Pushed the Silly Mode button today.
  2. #2 Re: The Official what you need and how-to for CTS-V brakes
    top 5 dead or alive OmegaRed's Avatar
    Feb 2010
    Medford, Oregon, United States
    yeah im staying away from drilled, just trying to see if theres more (affordable) options out there, 370z rotors wont work?
  3. #3 Re: The Official what you need and how-to for CTS-V brakes
    Quote Originally Posted by OmegaRed View Post
    Nope.
    Do remember some times going cheap on somethings is not always a good idea. $70/rotor is a pretty good deal IMO, especially for the size.
  4. #4 Re: The Official what you need and how-to for CTS-V brakes
    LOL Ya ignore my comment about the R1 Fbody rotors. I was thinking this was the other brake thread, that was a my bad.
  5. #5 Re: The Official what you need and how-to for CTS-V brakes
    Feb 2010
    you right you right
  6. #6 Re: The Official what you need and how-to for CTS-V brakes
    Dec 2010
    ATL,Georgia
    I got mine off Brakeperformance. com... they are drilled however but I've had no problems with them... I will say this as I'm sure Drunkie will.. don't get Hawk ceramics with these... they take forever to heat up if your not auto-xing... I will be getting semi metallics next lol
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  7. #7 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    whats everybody beef with drilled. ive had them on three of my last cars with no issues or cracking and damn sure no warping as compared to slotted. I think the diffrence is were they cast with holes vs. being drilled. and the overall quality of rotor/material/build quality.
  8. #8 Re: The Official what you need and how-to for CTS-V brakes
    Quote Originally Posted by 91parkave View Post
    Cross drilled rotor myths dissolved - 8th Generation Honda Civic Forum
    You're right there is a difference between cast with holes and being drilled...about the only ones that are cast with holes are pretty high end and only effective with actual race cars.
    They tend to be weaker since they are drilled and crack around that area. They're not needed unless your tracking the car and you tend to not be able to have them turned if needed.
    Enough of a reason not to purchase them and stick with either blanks or slotted.
    04 Comp G.
  10. #10 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    great read drunkie. Maybe im spoiled cause i have a GXP now before i had a GTP with GXP rotors/calipers and before that my 91 parkave had fbody BAER eradispeed rotors. all crossdrilled but then again i can agree with the logic in the thread you posted.
  11. #11 Re: The Official what you need and how-to for CTS-V brakes
    Feb 2010
    also, lol
  12. #12 Re: The Official what you need and how-to for CTS-V brakes
    Feb 2010
  13. #13 Re: The Official what you need and how-to for CTS-V brakes
    Feb 2010
  14. #14 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    Another endless question about this setup I keep seeing the rear calipers brembo still 4 piston, will those work as well?
  15. #15 Re: The Official what you need and how-to for CTS-V brakes
    No one has done the rear calipers, Alixor is trying it out. They don't just bolt up, he is having to make custom brackets. Then there is the rotors among other things.
  16. #16 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    Quote Originally Posted by Drunkie View Post
    sorry i shouldve been specific. what i mean is will the rear CTS-V calipers work as a swap onto the front for our car.
  17. #17 Re: The Official what you need and how-to for CTS-V brakes
    I have no idea. Your GXP calipers you have up front have more braking power than the rear CTS-V calipers
  18. #18 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    I have no idea.
    cause there way cheaper still 4 piston and i assume they have the 5.25 mount pattern the fronts have
  19. #19 Re: The Official what you need and how-to for CTS-V brakes
    I'd just keep your GXP Brakes
  20. #20 Re: The Official what you need and how-to for CTS-V brakes
    Arizona
    yea but brembos got sex appeal and it will compliment my 2 piece 13' rotors i have coming in. these things weigh 14-15lbs each which saves almost 10lbs off the driveline.
  1. Official Hello!
    By KawaFord in forum Introductions/Noob Questions
    Last Post: 08-17-2009, 03:56 AM
  2. Ok its official
    Last Post: 08-11-2009, 06:51 AM
  3. Its finally official
    Last Post: 04-03-2009, 09:57 AM
  4. Its Official; Im......
    By Toofastgs in forum The Rant Forum
    Last Post: 02-20-2008, 12:46 AM
