Thread: KYB Excel-G vs GR-2 - interesting discussion with KYB tech.
Results 1 to 20 of 76
  1. #1 Re: KYB Excel-G vs GR-2 - interesting discussion with KYB tech.
    who cares if they are the same. they will work fine, especially with some not even lowering the car SSCs...
  2. #2 Re: KYB Excel-G vs GR-2 - interesting discussion with KYB tech.
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    I wouldn't go stating "they will work fine" as fact considering how many people with GR-2 + Vogtland or SSC spring combos would beg to differ with you. There are plenty of complaints of those struts wearing out around 10k miles with lowered springs, even with ones as mild as Vogtlands/SSCs.
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    Ok so if i'm understanding this correctly the GR2's and the Excel's are identical except for the color. We just need to use the ones of a Monte due to them being a slightly different component to accomodate a lower car. Is this correct?
    More specifically, MCs and Impalas with the FE4 suspension package, which I believe started in '04. As to whether they'll accommodate a drop better or not, that's what we're trying to figure out now. Still need more details on exactly what the FE4 package entails. I've been digging around the net for info, but there's not much out there, even in the MC community. I did, however, find this on a thread...
    I e-mailed KYB and got this response:
    Are the 339015 and 339148 GR-2 struts structurally the same as the 334227 and 334228 struts? Meaning, is everything on the strut itself the same between the two models?
    No they are different in length, mounting and mouniting rates.
    If I was to get coil springs to drop my car around 1.5” can I use the GR-2s without voiding the warranty or do I have to use the AGX struts?
    If you modify your suspension with any springs non-oe design... this will void the warranty whether you use AGX or GR-2.
    FE3 vs. FE4 Suspension - Page 2 - Monte Carlo Forum - Monte Carlo Enthusiast Forums
    Apparently, the location of the perch-mount and such is different, too if you read through the rest of that thread. So this raises another question about fitment, though I can't see it being so different that they won't fit. I know it was mentioned that the FE4 struts are needed to clear the bigger wheels.
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  1. Separate general tech discussion
    By ZR1Vette09 in forum Forum Bugs/Suggestions
    Last Post: 05-02-2011, 01:20 AM
  2. oil additives discussion
    By apierce1289 in forum Engine
    Last Post: 04-21-2011, 04:31 PM
  3. Discussion on wheel hubs
    By BillBoost37 in forum Brakes/Suspension/Chassis
    Last Post: 01-04-2011, 08:55 AM
  4. Strut discussion
    By Warbeaver in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2010, 12:15 AM
  5. EGR Delete Benefits/Discussion
    By TyroElite in forum General Tech Discussion
    Last Post: 01-05-2008, 04:39 PM
