Thread: Magnasteer acting up after rack change?
Results 1 to 8 of 8
  1. #1 Magnasteer acting up after rack change?
    I just swapped my rack out on my 98 gtp because i only had power steering when turning right. The rack i got out of the junkyard and now my wheel turns itself all the way to either side with just the slightest movement of the wheel if you aren't holding on tight you end up on the sidewalk. I just took it around the block twice and it's ridiculous. If anyone has any suggestions i'd appreciate it I hate driving my minivan when i have a nice gtp sitting in the driveway.
  2. #2 Re: Magnasteer acting up after rack change?
    Pennsylvania
    Is your alignment way out of whack?
    I dunno if the pcm stores data on steering like it does the transmission, but it may be worthwhile to reset it by leaving the battery disconnected for a while. Or use a tuner.... there's definitely at least 3 different severity settings for magnasteer if you have a tuner
  3. #3 Re: Magnasteer acting up after rack change?
    well if you turn it it turns really hard then moves on it's own. I unhooked the wire for the magnasteer and it's still doing it. I thought it would just reset to the hardest setting but it still does the same thing.
  4. #4 Re: Magnasteer acting up after rack change?
    St. Louis
    I say dump the cables for a while and let everything reset then see what you get. Can't hurt and it's free to try.
  5. #5 Re: Magnasteer acting up after rack change?
    I unhooked the battery and no change. I just ordered a new one and I'm getting my money back from the junk yard
  6. #6 Re: Magnasteer acting up after rack change?
    I just installed my new one in the rain....it sucked but it's done now and i can drive my car again!!!!!! NO more minivan for me lol
  7. #7 Re: Magnasteer acting up after rack change?
    St. Louis
    So I take it the new Magnasteer rack works like it should?
    If so, congrats!! What a PITA to do in the rain.
  8. #8 Re: Magnasteer acting up after rack change?
    Yeah it all works like it should now i just have to get it aligned
  1. Is magnasteer and reg rack interchangable?
    By dsmuts in forum Brakes/Suspension/Chassis
    Last Post: 04-13-2011, 04:55 PM
  2. ABS and/or Magnasteer problems
    By cogsracing in forum Brakes/Suspension/Chassis
    Last Post: 02-02-2011, 08:33 PM
  3. Replace Magnasteer Rack with Regular Rack?
    By Smoker324 in forum General Tech Discussion
    Last Post: 06-29-2010, 09:11 PM
  4. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  5. 98 GTP acting up help!!!!!!!!!
    By Red_GTP in forum General Tech Discussion
    Last Post: 08-04-2008, 05:35 AM
