I think I shall make a new thread and everyone can join in there
If you guys are willing to help with the shipping costs then I'll go ahead and send them up his way. I dont use paypal though I use Serve.com way better service than paypal and no fees either.
Yes there's one right down the street actually. Do you want all 4 springs or just 2? Also how long would you need to keep them for?
Are they 17''s?!?! It doe look good!!! I like the back isn't sagging, mine probably look even with all my "junk in the trunk", lol! I was looking at springs that raise the back end and they claim it gives the front tires better traction...W Body Store
Vinnie spacers fixed my vibration issues...springs have settled even amount on each corner
What about B&G springs?
SSC rates are
190/140
So wtf is up with this 450/250 rating? That seems super stiffO
Um ok but I wanna use these on struts. Not coil overs. So. I want stance and ride quality. Not a **** ride and sag
So what's the best choice
If you want ride quality, go with moog stock replacements......and replace your old worn out bump rubbers. Unfortunately, the fact of life with modern cars are that they run super soft springs, with bump stops, so the general public will love the ride. When you take them out and thrash them, they ride on the bump rubbers, which make the effective spring rate go through the roof(almost like running a solid suspension). If you want to be able to lower the car, you have to increase the spring rate quite a bit, or otherwise they just end up running on the bump rubbers all the time. The reason I was looking at such a high rate is to eliminate the bump rubbers, and let the suspension work how it should. Yeah, it may not ride the best, but I want performance, not a perfect ride. In fact, the ride isn't always that bad with the stiffer springs. When I had the 275's on my coilovers on the rear, my wife actually liked the ride better. What will really make a difference is a really good strut. If you run stock replacement struts, they can not handle the rate, but if you go the way I did, and get Bilstein HD's, it makes a HUGE difference in the dampening rate, not to mention you get rid of the bump rubbers since they have internal bump stops. They are basically a coilover shock that is converted to a strut.
ok well i bought kyb GR2 loaded struts last year I want to use those so that DNA spring rate is probably the way to go?
dna is supposed to be pretty stiff rates, or at least they advertise 450/250......if you are running "stock" struts, probably go vogtland
