sometime when i start my 01 gtp my traction control light and traction control light stay on. Also the wheel is a bit harder to turn. It randomly comes on any ideas?
Is the ABS light on at the same time of the TRAC OFF light? If both lights are on then u might have a bad hub bearing. Have your scanned by someone with a ABS scanner
I second the movement! If you can't get it scanned, jack up the front end and see if you can wiggle either or both tires. If both seem good, try the rear.
Auto Zone's code reader won't read ABS codes. You'll have to go to a shop or maybe a place like Meineke that does brakes. They may have an ABS scanner.
