Thread: Stut mounts going, request your wisdom.
Results 1 to 8 of 8
  1. #1 Stut mounts going, request your wisdom.
    SE Level Member KZOO3800's Avatar
    Nov 2010
    Kalamazoo, MI
    97 Grand Prix SE with 3.8 NA.
    163K miles, all stock
    Dirt road...
    I bought my '97 Grand Prix with 159K miles, had no problems to date. Paid
    $1,400 for it and pretty sure I stole it from the sap who sold it to
    me. If I had the money I'd rebuild the engine and trans but I'm in my last
    semester of college and cant afford it until summer...
    I live on a dirt road, a BAD one. I'm talking about craters, not
    potholes. You could fit a fat lady and her whole plus-size wardrobe in
    these things... I've only put 4K on this car and i do no more than 15MPH
    down the road, no exceptions, but I can hear the struts knocking into the
    mounts from the wear and tear.
    My '94 Ford Escort would have driven to the moon and back, were it not for
    the "punch-through" symptom. Rear left strut came up through the mounting
    hardware and took out an Alpine speaker that was right above it. My guru
    machinist father and I welded the top of the strut back into the mounting
    surface with a solid chunk of steel. The fix lasted 6 months, then the surrounding, rusted out
    portions of the mounting surface "unzipped" around our handy work...
    Rocking the front end of my Grand Prix up and down by hand, the visible rubber portions of
    the mounts are "squishy". My concern is that the struts may punch through
    the mounts as they did on my '94 escort, or that the struts themselves may
    break from repeated, undamped impacts with the metal parts of what they're
    mounted to.
    I'm paranoid about the struts punching through the rusted out mounting surface, and my question is: can you replace just the hardware/surface that the top of a strut mounts to?
  2. #2 Re: Stut mounts going, request your wisdom.
    Omaha, NE
    Are you asking if you can replace the portion of the body that the top of the strut attaches to?
  3. #3 Re: Stut mounts going, request your wisdom.
    they're called strut mounts.
    you should invest in a set ASAP.
    They're actually pretty cheap too.
  4. #4 Re: Stut mounts going, request your wisdom.
    Jul 2010
    upstate NY
    If your strut towers (metal, part of the body) are rusted, then what happened to your Escort is a likely outcome for your GP. But in any case, before that happens you can very cheaply replace the mounts that attach the strut to the body since they are bolted on. But its the same amount of work to replace the strut at the same time since you'll have to take the strut out to replace the mounts.
  5. #5 Re: Stut mounts going, request your wisdom.
    Yes, replace the strut mounts.
    Then drive no more than 5mph. 15 is too damn fast for a crater road.
  6. #6 Re: Stut mounts going, request your wisdom.
    Nov 2010
    Kalamazoo, MI
    I know its a stupid question since I'm mechanically inclined... Just seems like it would make a LOT MORE sense if the very top of the strut towers could be replaced, AKA attached by a few bolts.
    The actual tower in general looks ok on my gp, no excessive rust except right by the mount. On the Escort the whole area of the body was rusted... Is it possible to replace the strut tower or would I have to find a talented body mechanic/fabricator?
  7. #7 Re: Stut mounts going, request your wisdom.
    GT Level Member dengnath's Avatar
    where can i get strut mounts besides zzp?
  8. #8 Re: Stut mounts going, request your wisdom.
    any parts store has the strut mounts.
    If its surface rust on the strut tower then you could try prep and paint.
    Once its rotted out you basically need a pro to fix it. (new car time)
  1. request
    By neyel8r in forum Forum Bugs/Suggestions
    Last Post: 08-17-2010, 08:28 PM
  2. I got my wisdom teeth pulled
    By Sandmaster in forum Off Topic Discussion
    Last Post: 04-24-2010, 01:48 PM
  3. Wisdom Teeth
    By eb08gprix in forum The Rant Forum
    Last Post: 07-09-2009, 12:04 PM
  4. Request for TDCRacing
    By tino153 in forum General Tech Discussion
    Last Post: 05-21-2009, 09:39 PM
