Thread: swaying on freeway
Results 1 to 18 of 18
  1. #1 swaying on freeway
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    my car is swaying on the freeway, going about 60-70 mph. I have checked the sway bar and all other suspension parts and nothing is loose. I just changed the outer tie rod. Could this be it or what else do you think it could be?
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  2. #2 Re: swaying on freeway
    did you have it aligned after you changed the tie-rod?
  3. #3 Re: swaying on freeway
    not yet. would that help? I have changed them before on other cars and nothing happend like that.
    Mods- Intake
  4. #4 Re: swaying on freeway
    it would probably fix it, most oem books call for it when you loosen suspension part and if your careful you can get away with it. but i would do it away just to make sure nothing is out of wack and wareing done anything else
  5. #5 Re: swaying on freeway
    im going to get it done this weekend.
    Mods- Intake
  6. #6 Re: swaying on freeway
    advance auto says it could be the sway bar link. i cant find the sway bar linkage. where is it?
    Mods- Intake
  7. #7 Re: swaying on freeway
    yea it could be that to but you would have problem everywhere not just on the freeway, but there is always that problem when you put new parts with old parts, the linkage should be on the bottem of the steering knuckle and run though a bushing that is bolted to the subframe
  8. #8 Re: swaying on freeway
    is it easy to change?
    Mods- Intake
  9. #9 Re: swaying on freeway
    yea its not that hard if you can change a tie rod then you should be fine but you will definitely need an alignment after(if) you change it
  10. #10 Re: swaying on freeway
    ok. reasonible to buy, and does it go out?
    Mods- Intake
  11. #11 Re: swaying on freeway
    depends on wear you find it, if "Does it go out" you mean does it wear out and go bad then yea just like everything else, just a maintenance thing, whats your mileage on your car
  12. #12 Re: swaying on freeway
    I have 124000 on my car .
    Mods- Intake
  13. #13 Re: swaying on freeway
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    They are cheap, I'd do those before you get the alignment and even if it doesn't fix it they should have been done anyways considering the car is 15 years old
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  14. #14 Re: swaying on freeway
    Quote Originally Posted by Dtrick22 View Post
    How do you have a home depot intake?
    Mods- Intake
  15. #15 Re: swaying on freeway
    because he made it on his own with parts from home depot.
  16. #16 Re: swaying on freeway
    Does anybody have a picture of the sway bar linkage? i cant find it on my car?
    Mods- Intake
  17. #17 Re: swaying on freeway
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    Not from a GP, this pic is from my Aurora but it's all similar. You can see the endlink snapped at the top, and the bar is floating above the broken endlink, just next to the tie-rod.
    2000 GP - 157K (DD/Crash damaged project)
    1995 Olds Aurora L47 - 222K
  18. #18 Re: swaying on freeway
    Reading the thread, I am wondering...what do you mean by swaying on the highway? You say that in your first post, and that's about all you say. From that we are assuming that something is going on with the car and that'll depend on our own personal interpretation.
    My intrepretation includes you wildly yanking the wheel left to right and thinking the car sways more than it should at highway speeds. That's typically sway bar/end link related. Others are clearly thinking that the car is pulling or not steering straight. This would be alignment related.
    After changing something like a tie rod that specifically changes the steering/alignment you should always get an alignment. You may only be a little off, but that can wear a tire over the next 20,000 miles etc. it would suck to kill a set of tires over an alignment.
    Please elaborate as to what swaying at highway speeds means to you.
    thanks
  1. A little freeway action...
    By IllegalIntentions in forum Track Sessions and Kills
    Last Post: 04-07-2010, 12:49 AM
  2. Another Toyota breaks loose on the freeway
    By DaytonaGTP in forum Off Topic Discussion
    Last Post: 03-20-2010, 01:25 PM
  3. car swaying side to side!
    By Conrad in forum General Tech Discussion
    Last Post: 04-19-2009, 06:22 AM
