Thread: Clunking Noise...
Results 1 to 7 of 7
  1. #1 Clunking Noise...
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Hey guys. Within the last month or so, my 2001 Grand Prix GT has been making a clunking noise from the front end (I think the passenger side). The only way it really happens is when I'm driving down a ramp or driveway, and pull onto flat ground. I know several different suspension components could cause this, but I just wanted to see what you guys think. Thanks!
  2. #2 Re: Clunking Noise...
    I think it's time to jack that side up and look around.
    Check balljoint and strut mount, sway end links, sway bar ends, sway center bushings. Those are the most common clunk items.
  3. #3 Re: Clunking Noise...
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Mine clunks and it is the ball joint, I'll get around to it if we get a warm day, but really the only way to figure it out is to get under there and check out the things Bill listed
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  4. #4 Re: Clunking Noise...
    SE Level Member scottgp34's Avatar
    ames, Iowa
    I am also getting a noise from the same area but also causes my car to shake like hell around 40-45 mph. Not a clue what it may be but its snowing like crazy so i won't be able to look at it today.
  5. #5 Re: Clunking Noise...
    GT Level Member donmega's Avatar
    St louis, mo
    cluck can be a strut or ball joint. only way to tell is to look
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  6. #6 Re: Clunking Noise...
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    just replaced the swaybar link on my 04. had a light clunk on rough roads. as said before could be a sway bar, strut(or upper strut mount), end link, etc
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  7. #7 Re: Clunking Noise...
    Jul 2010
    bettendorf ia
    could always be the intermdiate shaft too. they had a million bullitens on this.
    03 pontiac grand prix gtp limited edition
    02 chevy silverado 4x4
    97 pontiac sunfire
    87 ford mustang notch 408 stroker
  1. Clunking noise in front end 04 gtp!!!!
    By justin98 in forum General Tech Discussion
    Last Post: 11-08-2011, 03:19 PM
  2. Clunking noise over bumps
    By Amb4 in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2010, 08:26 PM
  3. Bad clunking noise and bad acceleration
    By ill12will8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2010, 03:00 PM
  4. clunking noise?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-07-2009, 02:55 AM
  5. *Clunking Noise From Front Left*
    By CleanGP in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2009, 01:12 PM
