Thread: Brake Pad Bonding Process
Results 1 to 10 of 10
  1. #1 Brake Pad Bonding Process
    Oklahoma
    I ran across this some time ago and its becoming more popular. Seems like a WAY better way to bond brake pads than the traditional adhesive.
    NUCAP:: NRS Stops Brake Noise
  2. #2 Re: Brake Pad Bonding Process
    PA
    Looks cool, and are on the Hawk pads I run now.
    But even in the past, I have not had a problem with pads coming unbonded. Maybe on race applications. But even drag racing, the brakes typically don't get hot.
    Just my $.02
    2001 GSE
  3. #3 Re: Brake Pad Bonding Process
    Oklahoma
    I agree, Ive never had a problem with brake pads delaminating or coming unglued. But I figure, if there is a better process, why not. I want to get new rotors and pads all the way around and have them cryo treated, so I might as well pony up and do it as best I can.
  4. #4 Re: Brake Pad Bonding Process
    TDCRacing
    Guest
    im due for brakes too...what is cryo treated? some type of coating correct?
  5. #5 Re: Brake Pad Bonding Process
    Barksdale AFB, LA
    They don't list Centric Posi Quiets, and these are the quietest brakes I have ever owned. One of the biggest fouls that causes noise while braking is the caliper piston moving against the pad backing, causing the metal on metal squeal.
    Centric's Posi Quiet brakes (along with other features) add a nylon/teflon shim that won't break down to the back of the pad. It's supposed to serve the same function as that "gel" stuff sold in auto parts stores, but does it much better. There is no longer metal on metal contact between the piston and pad backing, eliminating noise.
    Since I installed them, I have not heard noise from my brakes once.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Brake Pad Bonding Process
    St. Louis Mo.
    Quote Originally Posted by Sabrewings View Post
    I will back up my buddy Sabre here. I have a full set of Posi Quiet's myself and I could not be happier, and with the driving I do, a good mix of city and highway driving I have never heard one peep from them! And their bite is quite good and the dust is NOTHING
    James Shafer
    St. Louis MO
  7. #7 Re: Brake Pad Bonding Process
    Oklahoma
    Quote Originally Posted by TDCRacing View Post
    Cryo treatment is a computer controlled process of taking treated parts down to -300 degrees or more (-320 is about max). Its not a surface coating as with other process, rather the whole part, through and through, is treated and greatly reduces wear. You sacrifice nothing in braking ability but you severely reduce warpage and wear which gives your brake pads and rotors a much much longer life. It also aids in heat dissipation which would be a benefit for brakes as well.
    Do a google search and you will come up with a lot of good info.
  8. #8 Re: Brake Pad Bonding Process
    TDCRacing
    Guest
    Thanks scotty...i can always count on you for info
  9. #9 Re: Brake Pad Bonding Process
    TDCRacing
    Guest
    ok so can i get these at my local parts store- autozone,oreillys ect?
  10. #10 Re: Brake Pad Bonding Process
    Barksdale AFB, LA
    I've never seen them in a chain store before.
    Brake Warehouse (website) carries them. So does R1Concepts. Probably a lot more, since they're made by Centric, but I don't know off hand.
  1. Painting Brake Calpers
    By y1a3o in forum Visual/Body Modifications
    Last Post: 08-19-2008, 01:05 AM
  2. KVR big brake kit
    By robahr24 in forum Brakes/Suspension/Chassis
    Last Post: 07-06-2008, 07:00 PM
  3. 05 brake upgrade?????
    By duane9586 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2008, 02:47 PM
  4. parking brake light???
    By kingd44 in forum General Tech Discussion
    Last Post: 02-20-2008, 11:38 PM
  5. LS1 brake question
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2008, 12:14 PM
