Re: The Big Bad Brake Thread
Note all torque numbers are effectively useless except for relative comparative purposes.
This is because the brake proportioning valve rates are unknown.
2003 Pontiac Grand Prix - Specs, Specifications, Data
GTP curb: coupe: 3495 sedan: 3559
weight dist: 65/35
Rotor diameter (in / mm) front: 10.9 / 277; 10.9 / 277
Front force
Tw = 458.85 joules
Rear force
Tw = 346.85 joules
total 805.7 joules
f/r as percent
57/43
2005 Pontiac Grand Prix - Specs
S/C curb: 3583
weight dist: 62/38
Rotor diameter (in / mm) front 11.7 / 297
rear 10.5 / 270
Front force:
Tw = 492.01 joules
Rear force:
http://www.caranddriver.com/var/ezfl...f42798e242.pdf
GXP time
curb: 3632
Dist: 63.8/36.2
Front . . . . . . . . . . . . . 12.7 x 1.3-in vented and cross-drilled disc
Rear . . . . . . . . . . . . . . 12.0 x 1.0-in vented and cross-drilled disc
Front force: Tw = 755.60 joules
Rear force: Tw = 332.97 joules
Total: 1 088.57 joules
Dist: 69/31
Thus far: confusing to say the least.
2005 Chevrolet Impala - Specs, Data
SS: 3606
weight dist: 61 / 39
Rotor diameter x thickness (in / mm) front: 11.93 x 1.26 / 303 x 32
rear: 10.9 x .43 / 278 x 11
Front force:
Tw = 500.11 joules
Rear force:
Tw = 346.85 joules
Total: 846.96
Dist (F/R)
59%/41%
2009 Buick LaCrosse - Specs
2009 W body...
Curb: CXL (L26) 3502
Super (LS4) 3770
Weight dis: n/a?
Rotor diameter x thickness (in / mm) Front CX, CXL 11.7 x 1.26 / 297 x 32
Super 12.72 x 1.18 / 323 x 30
Rear CX, CXL 10.6 x 0.55 / 270 x 14
Super
10.94 x 0.43 / 278 x 11
Front force:
CXL:
Super: Tw = 755.60 joules
Rear force:
CXL:
Super: Tw = 332.97 joules
Total:
CXL:
Super: 1 088.57 joules
Dist:
CXL:
Super: 69/31
You have too much time on your hands...but thxgai
so if i'm good with just the caliper BRACKET and rotor, y was it listed under slight upgrade for 97-03 that i need the caliper too? or am i just being stupid and reading it wrong?
Because you can buy new calipers for dirt cheap then paint them while off the car.
Then swap them on with no downtime waiting for paint to dry.
Stock:
Tw = 8273708.75 Pa*0.00019949 m^2*0.5*2*0.278 m
Tw = 458.85 joules
Tw = 338.43 ft lbs.
60 mph, rotor spins at ~1850 RPM.
~119 HP... lulz.
I'm thinking of these items for my upgrade. Idea is for new parts, with a tilt toward economy versus performance. All are F-body items.
Calipers w/ brackets: Raybestos FRC10966 & FRC10965------------$120 for 2
Rotors: Raybestos 56641R------------------------------------------$66 for 2
Pads: Wagner MX749 -----------------------------------------------$36
Plus some sort of spacers.
So I am wondering if anybody has suggestions on:
A) Reduce cost without losing much quality or performance
B) Increase performance without increasing cost
According to the writeup this chit will be straight bolt on.
... $36 pads?
You're better off getting good pads and rotors and leaving the calipers stock.
That in itself would be a huge upgrade.
If that still wasn't enough, try 12" rotors.
Interesting. Not really looking for a fast wearing pad. Ahhh mind you expensive products sometimes win at more than one game.
Edit: I think the gain in diameter and caliper pressure/distribution is better than high end 11" brakes.
Stock:
Tw = 458.85 joules
F body calipers w/12" rotors:
Tw = 8273708.75 Pa*0.00028274 m^2*0.3*2*0.303 m
Tw = 425.29 joules
Downgrade FTW?
1. Why are you not calculating area of a cirlce using A=pi*r^2 ?
2. I thought Tw is torque at the wheel. Why do you have units of Joules, energy there? Cancel units and you can see it is N*m or ft*lb.
3. Can have a more accurate Re by finding the outer effective rotor diameter (well just use outer rotor diameter) and the inner effective diameter and taking their average. Neither of us want to bother with the more appropriate double integral in polar coordinates. Just saying using the effective diametral avg is better than the overall diameter.
4. Why in the post directly above, did you give me COF of 0.5 for the stock setup and COF of 0.3 for the F-body? You should compare a like for like pad compound. We are just trying to find the better mechanics of the two.
When the math is done the Tw is higher for F-body 12" brakes versus 11" stock brakes.
Edit: The assumption that pads are only effective under the piston is incorrect but depends on backing stiffness and proximity to the piston. Wish there was an easier way to account for that.
I think there was a guy a while back asking why brake upgrades can reduce stopping distances if the stock setup can already lock the brakes.
Very few cars can lock the brakes at 75MPH in good weather. A GP with 11" brakes certainly isn't one.
Bigger brakes reduce stopping distance for a few reasons, most notably my point directly above, but also the improved response that you get when the ABS is modulating. When ABS is active the braking is on and off.
cheap pads, lower coefficient.
I know the calcs are off. Couldnt be bothered to fix.
If you want to, go right ahead.
id just wait til i find a wrecked gxp or corvette and get the brake parts then... and just add new pads
so i dont know if any one will read this, but i am looking to do the f-body upgrade, and i am trying to find all the parts on autozones website.
the thing i am not so sure about is the banjo bolt i need. on there web site they list 2 different ones. one for like the 3.5 vs and one for the 3.9. which one do i get?
and just to check all i need for this upgrade is
1. brake pads
2. rotors
3. calipers
4. disk hardware kit
and i need to know what banjo bolt to get and if i need the caliper guide pin
is that everything?
thanks !
http://i240.photobucket.com/albums/f...804-001837.jpg
I bought drilled and slotted stock sized rotors from brakeperformance.com, painted the stock calipers and used cermaic premium pads. The braking performance is awesome and didnt cost much.
i might do that, but i still would like to know the banjo bolt to buy, and if the stainless steel lines are worth it. and what length also. i guess i should have put this in my first post. oh well
stainless lines are damn near the best thing you can do
for a car with old, weak rubber lines, sure.
if the lines are new and crisp you won't notice much difference. only old lines balloon and screw up pedal feel.
well my car is 5 years old with about 95000 miles. the pedel feels fine. but i have the keep this car for another 5 years or so, so i guess i might have to get them.
zzp sells them but they are like $100 or more. and autozone sells some stainless steel lines also, but they are universal but you can pick the length you want or need. has any one used those before?
^autozone sells them.......enough said. Unv fit doesn't fit 90 percent of the time. Probably shouldn't go cheap when its related to brakes
