I picked up a 98 GTP recently and it has 144k on the clock. I'm using it mostly for my winter car/daily driver. I will probably be driving it a lot becuase of my job.
Rear end sags and hits hard over bumps so I am assuming the struts needs to be replaced and the front passenger side strut mount is completely shot so I figured I would replace struts all around along with the mounts because of the mileage on the car.
From reading around on the board, Seems that the KYB-GR2 struts are the way to go. However, (over on rockauto), I see that the Monroe-Matic Struts were about 10-15 bucks cheaper and was wondering if anybody had any experience with these struts or I should just spend the extra 70 dollars for the KYB's all around......
The other question is if I could still use my stock springs, or should I 'spring' for new ones because of the mileage.
