Thread: brake light is on...
Page 1 of 3 123 LastLast
Results 1 to 20 of 55
  1. #1 brake light is on...
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    Hi all, my brake light came in and I am not sure what it means. The "brake" light , the exclamation point and the parking brake symbol. Im thinking it has something to do with the parking brake. I can get the light to go off if I brake real hard.
    So what is it?
  2. #2 Re: brake light is on...
    check your brake fluid in the master cylinder. if its low the light goes on.
    if the fluid is that low, you need new brakes too btw.
  3. #3 Re: brake light is on...
    This ^^^
  4. #4 Re: brake light is on...
    Or a line popped.
  5. #5 Re: brake light is on...
    Nov 2009
    chicago
    If a line popped wouldnt my brakes go out?
    Just checked the flud... it looks a little low.. I will top it off and see if the light goes off.
  6. #6 Re: brake light is on...
    If your fluid gets that low to set the light, likely you need to replace some brake pads and or rotors.
  7. #7 Re: brake light is on...
    Nov 2009
    chicago
    thanks guys.. went to the dealer to have an oil change and the rear brakes are down to 2mm.. Time for new brakes
    My dealer wanted over $400. of r just the rear brakes. Pads and rotors
    A local place that I usually go to want $350.00 ofr pads and rotors..
    I found Raybestos pads and rotors on Rockauto for $75.00 shipped.. I never did brakes before... not sure if I should try, but to save $300.00 seems worth it.
    Any recomendations on pads and rotors?
  8. #8 Re: brake light is on...
    We can walk you through it... On the rear, you can use nearly any pads/rotors because they hardly do any of the braking. Most of it is done in the front.
  9. #9 Re: brake light is on...
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I used raybestos rotors and wagner ceramic pads on my car when I did my brakes then used a tube and water bottle to bleed them by myself. No complaints with them, yay no brake dust.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  10. #10 Re: brake light is on...
    Donating User Odi's Avatar
    Chicago South Suburbs
    just threw Advance One pads from NAPA few days ago, pretty happy with them so far.
  11. #11 Re: brake light is on...
    No need to bleed them if you're just swaPping the pads and rotors. Get a rear brake tool from harbor freight fit about $35 I'll make your life much easier
  12. #12 Re: brake light is on...
    Quote Originally Posted by andremike View Post
    pretty sure a brake job was one of my very first repairs every. brakes are so easy its not funny. once your done you'll drive by that shop flipping him the bird.
    being you were kinda set on spending 300 or so, you could up grade your brakes to F body brakes for that much, or less if you shop smart.
  13. #13 Re: brake light is on...
    Nov 2009
    chicago
    I have been watching utube videos and it does seem kind of easy... here are mg concerns..
    WhT brake tool do I need?
    Does the caliper pin just get compressed back with a c clamp or do I need to get the square tool and rotate it?
    do I need to use antiseize on the rotors?
    Do I need to greese the bolts that hold the caliper on?
    Do I need any other chemicals?
  14. #14 Re: brake light is on...
    Nov 2009
    chicago
  15. #15 Re: brake light is on...
    only brake tool you will need is a rear bake caliper tool. the rears piston of the caliper need to be turned back in,
    normally you can use a old brake pad and a c clamp to push the piston back in.
    the bolts that hold the caliper to the bracket are long slider pins, re grease them with high heat brake grease. just the long smooth part, not the threads.
    no chemicals are needed, buy maybe some brake cleaner if your doing new rotors as well.
  16. #16 Re: brake light is on...
    1. Loosen lugs a little if you don't have cool tools
    2. Jack and support car
    3. Pull rear wheels
    4. Loosen master cylinder cap (this allows the fluid to push bad easier)
    5. Remove caliper and turn in piston
  17. #17 Re: brake light is on...
    Nov 2009
    chicago
    Does anyone know for sure if the piston turns or pushes in. Should I buy that square tool that allow mw to rotate the pin back
    And yes I plan on replacing the rotors.. so what else do I need
    What is tge s drag reduction clip? Do I need it?
  18. #18 Re: brake light is on...
    Nov 2009
    chicago
    any recomendation on pads? Here is what I see on rockauto..
    WAGNER Part # PD698 ThermoQuiet Installation Hardware Included (Rebate/Promotion Available!)
    Rear; Organic
    RAYBESTOS Part # PGD698C {#PGD698} Professional Grade - Ceramic
    Rear; Drag Reduction Clip Recommended H6002; OE Pad Material is Organic
    ACDELCO Part # 17D698CH {#19286309} Professional Durastop|Ceramic| - Ceramic w/Hardware
    Rear; Installation Hardware Included; Ceramic; OE Pad Material is Organic
    RAYBESTOS Part # ATD698C {#PGD698QS} Advanced Technology - Ceramic w/Hardware
    ACDELCO Part # 171592 {#18029844}
    Rear
  19. #19 Re: brake light is on...
    That square tool is junk get the proper tool
  20. #20 Re: brake light is on...
    Nov 2009
    chicago
    The square tool looked like it would of done the trick. It looked easy on utube....
    Should I buy this then?
    http://www.harborfreight.com/disc-br...-pc-69053.html
  1. Replies: 2
    Last Post: 07-20-2013, 08:25 AM
  2. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  3. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  4. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  5. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
