Thread: LCA removal, What size torx?
Results 1 to 5 of 5
  1. #1 LCA removal, What size torx?
    SE Level Member Boosted02GTP's Avatar
    Feb 2009
    Long Grove IL.
    I need to replace the lower control on my GTP and I can't find any information on the Torx size for the front bolt. I don't want to spend the money on an entire set. Any info on this would help me!!
    2002 GTP coup 14.6 @ 94mph stock baseline 5-7psi.
    Headers w/o cat, plugs, fwi, 180* t-stat, 3.4, mail-in tune. 13.9 @ 99.75mph 2.2 60'..seeing only 7psi and a fresh set of weatherman snow tires
  2. #2 Re: LCA removal, What size torx?
    Donating Users
    South Deerfield, MA
    T55
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: LCA removal, What size torx?
    Feb 2009
    Long Grove IL.
    AHHHH thank you so muchhhh. You sir just made my day!!
  4. #4 Re: LCA removal, What size torx?
    Donating Users
    South Deerfield, MA
    Glad to help
  5. #5 Re: LCA removal, What size torx?
    Feb 2009
    Long Grove IL.
    I just wanted to say thank you again! People like you are an asset to the online community. I replaced the control arm last night and it's a total 180 from the old one with blown bushings. Today I'm doing the steering tie rods then taking it in for a full alignment.
    You saved me about $35 from my local parts store. The single T55 was $4.99. Thanks again!!
  1. Torx size for front seats
    By Joe in forum General Tech Discussion
    Last Post: 10-15-2009, 04:21 PM
  2. What size torx for lower control arm screw
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 05-20-2009, 08:38 PM
  3. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
  4. Where to find torx studs
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2008, 07:05 PM
  5. stock size? PLEASE HELP on piping and 2.25 muffler size
    Last Post: 07-27-2008, 09:52 PM
