Where to find this revised harness?
i would imagine a pontiac dealer if you can find one. Could always try a gm dealer
Part # 10340315 (right)
10340317(left)
'02 right?
alldata TSB says
abs lamp intermittent or constant:
Cause: The front wheel speed sensor harness may wear or contact the tie rod stud. in this case the wheel speed sensor should be examined for damage.
Correction: Replace the wss harness by splicing in revised wss harness. the new design harnesses are different length and have revised retention clip locations.
