Yes. The tie rod is what adjusts how much toe in the wheel has. You'll notice after changing it that the steering wheel will be off driving forward in a straight line. You can get it pretty close if you adjust it until the steering wheel sits in the same place it did with the old tie rod end. You should have it aligned at a shop to make sure it is right on.
