Thread: vibration at 55mph and hard steer
Results 1 to 12 of 12
  1. #1 vibration at 55mph and hard steer
    Jul 2010
    Outside ATL
    My car set for about 2 years while i gave the state some good quality free work via the GDC. When i returned home i assumed there would be some issues with the gtp.
    The first thing i noticed after the appropriate oil change, air filter clean, and leak inspection was hard steer. I noticed today going really slow like a creep it felt like my left side was going over bumps about every 5 ft going about 5-8 mph. It was not rough but like a smooth slope then a drop. Now, when i am mobile, like backing into a parking space or slowly go about a round about it is like killer to turn. Well i thought the ps pump was going bad or leaking, i checked the level and i was almost full. I was like what is the deal here, i topped it off and the issue still continued.
    Well as i drove it up to speed i noticed a shake at about 55-60 no less, no more really. I thought maybe my rotors where warped or something so I did a 12 inch brake upgrade while i needed new rotors anyways. I was bedding the brakes in yesterday so i didnt really get a chance to check the vibration too well but i think its still there a little.
    Anyways sorry so long, while i was doing the upgrade i noticed my cv boot was torn at the lower position next to the wheel. I really know nothing about steering or rack and pinion compared to my other knowledge so im stumped. Any help troubleshooting would be AWESOME
  2. #2 Re: vibration at 55mph and hard steer
    Jul 2010
    Outside ATL
    anybody got any clue where to start?
  3. #3 Re: vibration at 55mph and hard steer
    GTX Level Member cerick08GP's Avatar
    Well, I can tell you this you need a new half shaft. What ever side you have that cut boot is the side you need to replace. CV joints don’t last long once the boot is damaged.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: vibration at 55mph and hard steer
    Portland Oregon
    If the vibration persists after you replace the axle, jack the car up on both sides and check for up and down play in the wheel bearings. You can do this by pushing alternately on the top and bottom of the tire and seeing if there's play. Chances are you're ready for a new set of front wheel bearings.
  5. #5 Re: vibration at 55mph and hard steer
    Jul 2010
    Outside ATL
    Quote Originally Posted by cerick08GP View Post
    cant i just replace the boot? The weird bobble is on the other side of the car. I put the car in reverse turned the wheel all the way and did some reverse circles going both directions and felt nothing weird or heard no noise.
  6. #6 Re: vibration at 55mph and hard steer
    Jul 2010
    Outside ATL
    Quote Originally Posted by OH4CompG View Post
    will check this asap, thanks!
  7. #7 Re: vibration at 55mph and hard steer
    Jul 2010
    Outside ATL
    i guess i might as well replace the whole axle if the boot is torn anyways, but can i just pack it with grease and repair the boot ( i found a quick repair quide on-line) until i can replace it. Also, what is causing my steering to be so hard to turn, i am not hearing any noise from the pspump at all, just a bit*h to turn.
  8. #8 Re: vibration at 55mph and hard steer
    Aug 2008
    KCMO
    halfshafts are 60 bucks at oriellys and they are pretty easy to change out. just did both of mine last weak. trying to figure out my vibration i have between 55 and 75.
  9. #9 Re: vibration at 55mph and hard steer
    Jul 2010
    Outside ATL
    Quote Originally Posted by carl06GT View Post
    is that rebuilt or new for 60
    what method did you use to change it out (dropping the strut) or another way. Ive seen several diff ways, i want to know which one is easiest.
  10. #10 Re: vibration at 55mph and hard steer
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    the vibrations are probably from your tires.
    After sitting for two years, probably flat spotted.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  11. #11 Re: vibration at 55mph and hard steer
    Jul 2010
    Outside ATL
    Quote Originally Posted by Ridin ON Chrome View Post
    never thought about that, I guess ill check the wheel bearings today and rule that out.
  12. #12 Re: vibration at 55mph and hard steer
    Aug 2008
    KCMO
    Quote Originally Posted by TheBeastGTP View Post
    rebuilt.i just dropped the lower control arm.
  1. 1500RPM at 55MPH in '08 GXP? (MD)
    By cprher in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2010, 08:36 PM
  2. noise when i steer
    By mezzoni in forum General Tech Discussion
    Last Post: 03-24-2010, 10:29 PM
  3. Torque Steer?
    By jdkhunter in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2009, 04:07 PM
  4. can you say torque steer?
    By 99gpse in forum Off Topic Discussion
    Last Post: 03-30-2009, 05:18 PM
  5. Hard to steer left
    By bronzegp in forum General Tech Discussion
    Last Post: 03-05-2009, 07:37 PM
