Hey guys,
I noticed some funny vibration and took a peak under my 2006 GP to see what I could see and it looks like the heat shield (i think that's what it is?) has been knocked off its mount.
I figured I could just unscrew the knob, push the shield back into place, and screw the knob back in... but I then I realized that the knob might be some kind of plug on the gas tank (which is half full at the moment) and the last thing I want is to be hosed down with gasoline.
I took a few pictures in hopes of getting some feedback here.
You can see the heat shield hanging down here:
Here's the mounting hole on the shield:
And here's the part that goes through the mounting hole which is connected to the gas tank, as seen in the first picture... I'm guessing it's held in place with a phillips screw in the center of the hole.
Any ideas?
Thanks!
edit: I'm not sure if this was the best subforum or not - sorry if it should be somewhere else.
