Thread: Front brake rotors warped (again)
Results 1 to 11 of 11
  1. #1 Re: Front brake rotors warped (again)
    HUDSON
    Is it the pedal pulsating, or is it the body vibrating?
    I did brakes on my GTP 25,000 mile ago and still smooth.
    I bought the better pads and rotors from Rockauto.com.
    They cost a little bit more but are still smooth.
    I also agree with aboove, driving style does have a part
    to play when it comes to brake wear and tear. Now I am
    not totally easy on my brake either, I like to lay into them hard
    once and a while to see how they are grabbing if I need the
    extra stopping power.
  2. #2 Re: Front brake rotors warped (again)
    Being that the car has a little age on it, another thing to consider is the rubber hoses going to the calipers. The rubber over time does come apart inside and this will act like a partial check valve. It can heat up rotors and cause warpage. Usually hoses are about $12 a side.
  1. Brake Rotors
    By SliceTheRice in forum Brakes/Suspension/Chassis
    Last Post: 07-16-2010, 10:47 AM
  2. brake rotors warped
    By Will5600 in forum General Tech Discussion
    Last Post: 06-02-2010, 04:06 PM
  3. Brake Pads and rotors
    By packerfanjc in forum General Tech Discussion
    Last Post: 01-20-2010, 09:49 PM
  4. Brake pads for d/s rotors
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2009, 03:24 PM
  5. V 12 brake shop rotors
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 04-23-2008, 02:40 PM
