Thread: Front brake rotors warped (again)
Results 1 to 11 of 11
  1. #1 Re: Front brake rotors warped (again)
    GT Level Member Lvgrandprix2003's Avatar
    Cincinnati
    Driving habits can cause a lot of brake issues. My father-in-law goes through brakes real bad. I have gone from Ceramic to semi metallic, From Cheap to expensive. He warps rotors like crazy, drives his automatic with both feet and constantly rides peoples rears! I'm not jumping to conclusions, just saying that may be some or most of the issue. My Wifes 04 GTP only went through one set of brakes and we owned it till we had 80K on it.
  2. #2 Re: Front brake rotors warped (again)
    Pennsylvania
    Well, time is one thing, mileage is another. How many miles do you put on in 6 months? Do you start to brake for 3000 feet before a stop?
  3. #3 Re: Front brake rotors warped (again)
    Feb 2009
    West Michigan
    Quote Originally Posted by Lvgrandprix2003 View Post
    I'm thinking about going with good rotors again but maybe drop down to semi-metallic pads? Other than the dust, would there be another reason not to go this route? Reason being is I've been told the ceramics run hotter. It's just odd that the original OEM pads and rotors lasted for ~60k and then we can't get 15k miles out of rotors due to them warping. My wife does like to brake and I think this last warpage was due to the stop and go traffic we encountered around Atlanta coming back from spring break this year. 70 down to 0 then vice versa and all over again. I'm sure this didn't help the rotors.
  4. #4 Re: Front brake rotors warped (again)
    Cincinnati
    Quote Originally Posted by mntnbiker View Post
    Our GTP had over 43 on our original brakes, then we went to the Smokey mountains and that finished them off. The Rotors are EVERYTHING! 70 to 0 multiple times with luggage in the back is not good on the rotors. I went with Raybestos all the way around with ceramic pads and the highest quality rotor raybestos sold for the car at the time. Semi Metalic would work on your rotors less, but like you said more dust, and I think you will have to replace the pads more often than the ceramics.
  5. #5 Re: Front brake rotors warped (again)
    Feb 2009
    West Michigan
    What about going with some Brembo slotted and cross drilled rotors? I've heard pros and cons to cross drilled rotors. I've heard to stay away from the ones with cast holes and cast slots. Brembo's are drilled holes and machined slots.
    Anyone ever use these? Better braking? Worse braking? Do they really not heat up as much as OE rotors as they claim (200 degree reduction in rotor heat - really?).
  6. #6 Re: Front brake rotors warped (again)
    Cincinnati
    Slotted rotors do run cooler, But Brembo brakes and rotors run coller for the simple fact that you have more surface area and mass to the rotors on Brambos. Thermodynamics comes in to play and transference of heat is not as rapid and the rotors will stay cooler. If it was me, I would focus on driving habbits and maybe purchase lifetime warranty brakes and rotors from your local autoparts store. You will be out your time but not money when you have to take them back every 15 to 20K miles.
  7. #7 Re: Front brake rotors warped (again)
    Feb 2009
    West Michigan
    It's my wife's daily driver
    I may check into some life time rotors and pads - great idea!!!
  8. #8 Re: Front brake rotors warped (again)
    Cincinnati
    I not sure if they have life time rotors, but pads I am sure of.
  1. Brake Rotors
    By SliceTheRice in forum Brakes/Suspension/Chassis
    Last Post: 07-16-2010, 10:47 AM
  2. brake rotors warped
    By Will5600 in forum General Tech Discussion
    Last Post: 06-02-2010, 04:06 PM
  3. Brake Pads and rotors
    By packerfanjc in forum General Tech Discussion
    Last Post: 01-20-2010, 09:49 PM
  4. Brake pads for d/s rotors
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2009, 03:24 PM
  5. V 12 brake shop rotors
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 04-23-2008, 02:40 PM
