I'm probably missing something, but I can't get the rear rotors off. Tire is off, calipar is off. I found the two TORX screws behind the rotor. The one closest to the rear is a little difficult to get to but I can loosen it and can remove it easily. The other TORX screw is behind the parking break line, I think. Do I need to loosen and/or remove it as well to take the rotor off? I've got some torx bits, but I can't quite fit it in there. Do I need to get a special longer TORX bit or something to reach it? Or do I just need to beat the crap out of it with a hammer after spraying plenty of PB Blaster on it?
