Thread: Which rotors can go from '04 Imp to '00 GP
Results 1 to 5 of 5
  1. #1 Which rotors can go from '04 Imp to '00 GP
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I have to put some new rotors on my GP. Rears at a minimum, probably will do all four. So I've considered taking the rotors off my Impala and buying new ones for it, then putting the Imp rotors on my GP. Factory stuff still on them all around. What can I swap/move without having to upgrade brake caliper hardware? I think the Imp has 12" fronts, 10" rears, and the GP has 10" on both.
    ZZP has fronts and rears for $50 each, so I've also thought of just buying 4 new ones for the GP and worry about the Imp rotors later as it would probably make more sense to do all four at once.
    Thoughts/suggestions/deals on rotors?
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  2. #2 Re: Which rotors can go from '04 Imp to '00 GP
    Rockauto has a great interchange DB. Just click on the part number for the Imp and see if the GP is listed.
    ZZP for rotors, aren't they stockers? Why not go with some higher end stuff like R1 or others?
  3. #3 Re: Which rotors can go from '04 Imp to '00 GP
    Feb 2008
    Cumming GA
    Might just go with cheapos on the GP for now. Looking at RockAuto and several others, rotors are priced right, but shipping is the killer. I can get all four right now from Advance Auto with a coupon for a little over $100. I'll upgrade the Impala ones later.
  4. #4 Re: Which rotors can go from '04 Imp to '00 GP
    Donating Users kfish's Avatar
    Ohio
    to use the impala rotors you need to used the impala caliper bracket too.
  5. #5 Re: Which rotors can go from '04 Imp to '00 GP
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    yeah, your impala has 12" brakes. So if your going to swap. You will have to swap brackets too.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. m90 Rotors
    By Lion29GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2010, 10:27 PM
  2. need some help with rotors
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2009, 11:16 PM
  3. will these rotors fit?
    By 2000GTP in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2009, 04:39 PM
  4. rotors?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2009, 09:37 PM
