Thread: Rear end Sag
Results 1 to 13 of 13
  1. #1 Rear end Sag
    SE Level Member Pontiac Warrior's Avatar
    Hudsonville
    My rear end sags pretty bad on the passenger side and just a little on the Drivers. Wondering if a busted sway bar may cause this or if i am looking at new struts? Any suggestions of good struts on a budget? Any ideaas what is cuasing this if not the struts? Thanks everyone!
    Pontiac Warrior
  2. #2 Re: Rear end Sag
    Donating Users Ibwrong's Avatar
    Oklahoma City
    These W bodys are notorious for rear end sag.. Between springs and struts you should be good to go again.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: Rear end Sag
    GT Level Member hourang's Avatar
    commerce, mi
    springs are most likely warn out. the springs hold the weight of the car, the struts just dampen the up/down movement. mine is doing the same, but it is not cheap to replace springs and you will want to do both anyway.
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  4. #4 Re: Rear end Sag
    Oklahoma City
    I paid 115.00 (shipped) for my springs off ebay lol....
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  5. #5 Re: Rear end Sag
    no, you ALWAYS replace springs in pairs.
  6. #6 Re: Rear end Sag
    Dec 2008
    Lawndale, CA
    Look into springs form an olds intrigue. They will raise the rear right back up.
  7. #7 Re: Rear end Sag
    Willoughby, Ohio
    the weight of my system ruined my struts, i replaced struts, springs, mounts, and harware and sold the system now it looks better
  8. #8 Re: Rear end Sag
    MA
    Quote Originally Posted by The Guz View Post
    Really? perfect swap no modifications?
    SMGPFC Member #9
  9. #9 Re: Rear end Sag
  10. #10 Re: Rear end Sag
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    That is good to know. Weather is fine for a junkyard crawl....
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  11. #11 Re: Rear end Sag
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by SilvaMan61 View Post
    They will fit rght in. Straight swap.
  12. #12 Re: Rear end Sag
    SE Level Member techweenie's Avatar
    Nov 2009
    Grand Blanc, MI
    Monroe is offering a hefty rebate on all their struts right now. I just ordered the rear sensa-trac quick struts for my car which qualifies for a $60 rebate. After all is said and done it works out to ~$100 each from Rock Auto.
  13. #13 Re: Rear end Sag
    Rio WI
    Autoparts123.com, has all 4 preloaded sets front and rear for $516 with free shipping. Monroe's rebate is $150 for the 4 of them and there was a 10% promo code, so after all was said and done it the cost per unit came down to 79 per unit.
  1. rear STB
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 12-08-2009, 01:54 PM
  2. Rear End Help
    By Juice-08 in forum Visual/Body Modifications
    Last Post: 06-03-2009, 07:13 PM
  3. rear o2
    Last Post: 04-21-2009, 02:54 PM
  4. Rear STB only...
    By a3gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-08-2009, 06:17 PM
