Hi there. I've been doing some reading online and I have some idea whats going on, but I figured I'd run it past you guys and see what you think, So thanks in advance for any ideas.
For the past while I've noticed that when I make a left turn with the window open I can hear rubbing from the front drivers side wheel, but wasn't sure what was causing it. I also have noticed that when I brake hard the steering wheel literally pulls left in my hand. I figure that they're related and that its a bad caliper, or possible the brake line/hose leading up to it is pluuged, however if my understanding is correct then if the left front wheel is the one with the bad caliper then wouldn't it pull right instead of left? Or maybe I'm wrong all together and you guys might have an idea, or two.
