Thread: Alignment kits?
Results 1 to 4 of 4
  1. #1 Alignment kits?
    SE Level Member Amb4's Avatar
    Nov 2009
    Canada
    I just lowered my car and i want to get it aligned. I tried the shorter dog bones but they dont fit on my car because of the headers. So i was going to go with motor and trans spacers, but what i really want to know is which of these three options will be the best for camber and even tire wear?
    Also does the eibach alignment kit even work with the newer model grand prixs?
  2. #2 Re: Alignment kits?
    youre going to want the spacers if you cant run the dogbones. the eibach alignment kit just gives you camber bolts, which you can get cheaper elsewhere.
  3. #3 Re: Alignment kits?
    Nov 2009
    Canada
    alright thanks for your help Bio, im going to try and re make my dog bones so they are longer but yet shorter than stock. That should help. You said in your lowering thread the proper size is 3/4 inch from the stock and not the 1 inch like i have now.
  4. #4 Re: Alignment kits?
    yeah, the 3/4" is more of a correct alignment for the setup. the 1" shorter ones are actually off a montana mini van so they are cheap and easy to sell for a profit for the people selling them.
  1. Wheel alignment
    By kissmyss in forum General Tech Discussion
    Last Post: 04-19-2010, 12:13 PM
  2. HIDS, Alignment and Flickering
    By Spartan GL in forum Visual/Body Modifications
    Last Post: 01-13-2010, 04:57 AM
  3. alignment specs.
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2009, 02:40 PM
  4. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
  5. headlight patter alignment.
    By riceburner in forum Visual/Body Modifications
    Last Post: 09-04-2008, 11:16 AM
