Thread: bolts on fbody brake upgrade
Results 21 to 40 of 41
  1. #21 Re: bolts on fbody brake upgrade
    SE Level Member d8teen's Avatar
    Jul 2010
    Fl-Hollywood
    LOl it was so late. 6 am. Not 14" but 14mm
  2. #22 Re: bolts on fbody brake upgrade
    Jul 2010
    Fl-Hollywood
    So, im back home. and disappointed nobody here could do re-tap for me. I will be using sleeves.
  3. #23 Re: bolts on fbody brake upgrade
    Nothing wrong with sleeves...I use them.
  4. #24 Re: bolts on fbody brake upgrade
    hanover park, IL
    Quote Originally Posted by Ridin ON Chrome View Post
    why the hell not
    I have been running them for over 4 years never had any problems.
    Dont be spitting that bull ****
    Yes tapping them is the proper way, but the sleeves work fine.
    Have you looked at your car.....why would you not do it properly lol
    The only reason anyones bracket bolts losened after a couplebrakes is because they never tightened them properly t begin with.
    I order drilled and slotted rotors, just got my brackets back from the machine shop so ill be doing my brakes next weekend
  5. #25 Re: bolts on fbody brake upgrade
    Recently people have started listening to the solid rotor school.
  6. #26 Re: bolts on fbody brake upgrade
    hanover park, IL
    Whys that?
  7. #27 Re: bolts on fbody brake upgrade
    Drilled rotors crack.
  8. #28 Re: bolts on fbody brake upgrade
    hanover park, IL
    Don't mean to thread jack but what do we typically do to firm up the pedal after the fbody swap. I've heard it feels kinda spongey. Different master cylinder? Bigger brake lines?
    2000 gtp- u-bend and res delete, hot air intake, flipped mounts, 104s, larger front sway bar, fbody front brakes, custom embroided floormats, custom carpeting,
  9. #29 Re: bolts on fbody brake upgrade
    Buy C5 or LS2 C6 calipers instead.
    Bigger wont solve your problem.
    You'll want a 00-05 impala brake booster and stainless lines.
    Though there were reports here and there of stainless lines breaking. Unsure how that ended.
  10. #30 Re: bolts on fbody brake upgrade
    Matt...is that only on Canadian metal? I jumped on the wagon for drilled slotted just because I could try them out. Crappy rotors will crack, Baer and R1 Concepts (should be Centric blanks) havent' thought about cracking or anything. I'm constantly showing people how great they stop.
    Bumping a 5 month old thread FTW!
  11. #31 Re: bolts on fbody brake upgrade
    centric premiums are cheaper and perform just as well.
    Unless the veins are curved there is no point in opting for those rotors.
    Its more in the pad/rotorsize/caliper/suspension that determines your braking performance.
    Even moreso is your tire choice.
  12. #32 Re: bolts on fbody brake upgrade
    I understand all that. Moreso addressing your general statement about drilled cracking. They don't all crack, they aren't all crap and I've had cracks in solid face rotors plenty of times.
    The reality is.. crappy rotors are crappy.
  13. #33 Re: bolts on fbody brake upgrade
    hanover park, IL
    Agreed
  14. #34 Re: bolts on fbody brake upgrade
    China made rotors are more prone to failure more than anything else.
    But I will testify to the death that Drilled rotors are not the way to go.
  15. #35 Re: bolts on fbody brake upgrade
    no one needs drilled and slotted rotors on the street. if you do, because youre fading them all the time, youre driving like an asshole and need to knock it off.
  16. #36 Re: bolts on fbody brake upgrade
    hanover park, IL
    Im not buying drilled and slotted rotors for their purpose im buying them for looks
  17. #37 Re: bolts on fbody brake upgrade
    No need to.. honestly take it from a guy that has them. It doesn't impress you much after a couple of weeks. Save that dinero, but... if I may suggest the R1's. They start off as centric blanks then they coat them.
    I've had them on my all season DD for a year. Not a bit of rust in the fins or on them at all. I am impressed.
  18. #38 Re: bolts on fbody brake upgrade
    SE Level Member Crave Energy's Avatar
    Oct 2008
    San Jose
    I've been running the R1 rotors for almost a year too and very happy with them!
  19. #39 Re: bolts on fbody brake upgrade
    centrics come coated?
  20. #40 Re: bolts on fbody brake upgrade
    Possibly. I've heard R1 coats them. Maybe it's a second coating, maybe it's the first coating on the Centric. Honesly ...I dunno enough about it. I gave something a try and am here to report that all drilled rotors don't crack and R1 eline rotors haven't rusted on me, in a horrible winter of driving.
  1. fbody brake question
    By silvermistgt2002 in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2009, 11:12 PM
  2. Fbody brake line question
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 05-09-2009, 05:00 PM
  3. fbody brake upgrade
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2008, 09:59 AM
  4. longer SS brake lines (fbody brakes)
    By UR LOSN in forum Brakes/Suspension/Chassis
    Last Post: 03-30-2008, 02:38 PM
