Thread: noob question about two bolts in the suspension..
Results 1 to 19 of 19
  1. #1 noob question about two bolts in the suspension..
    Feb 2010
    atlanta
    are these bolts in the picture known to seize up?? tried to take them off but couldnt turn them at all. help!! lol
    the nuts on the back of the bolt came rite off... am i supposed to hammer them out a little??
  2. #2 Re: noob question about two bolts in the suspension..
    Aug 2008
    KCMO
    squirt some powerblaster on them and let it soak in for a day or so. you said you got the nuts off but cant get the bolts out? put the nuts back on until they are fluch with the end of the bolts and then hit it with a hammer that shoudl get them out
  3. #3 Re: noob question about two bolts in the suspension..
    Feb 2010
    atlanta
    thanks..
  4. #4 Re: noob question about two bolts in the suspension..
    Willoughby, Ohio
    they are probably just stuck because its on a moving part, i agree hit it with something
  5. #5 Re: noob question about two bolts in the suspension..
    Aug 2008
    KCMO
    just make sure you put the nuts flush on the end of the bolt or otherwise your not getting the nuts on or off those bolts
  6. #6 Re: noob question about two bolts in the suspension..
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    Yes, the bolts holding your control arm to the strut need to be hammered out. There are lines on the bolt near the head to prevent any movement whatsoever while assembled. It'll take 15-20 solid hammer drops to break them loose. I'd recommend putting some Never-Seize on them to help in the future.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  7. #7 Re: noob question about two bolts in the suspension..
    Nov 2009
    Grand haven
    BFH will get them out.
  8. #8 Re: noob question about two bolts in the suspension..
    Apr 2009
    stockton ca
    Pb blaster BFH to shock the bolt and a impact Mine came out no prob with a 1/2 inch snap on impact
  9. #9 Re: noob question about two bolts in the suspension..
    Charles City, IA
    You pound them out. They do not twist out.
    SMGPFC Two Nipple General
  10. #10 Re: noob question about two bolts in the suspension..
    Cant wait to replace my struts now =D
  11. #11 Re: noob question about two bolts in the suspension..
    Apr 2009
    stockton ca
    its not bad just hit em with blaster and wait a lil bit
    Biggest thing is using an impact on em
  12. #12 Re: noob question about two bolts in the suspension..
    Charles City, IA
    Quote Originally Posted by TorqueAutoMotiv View Post
    No the biggest thing is they pound out. The splines are there to make is easier to just loosen the nuts to adjust camber.
  13. #13 Re: noob question about two bolts in the suspension..
    Apr 2009
    stockton ca
    Oh i know they dont spin out I was talking the actual nuts
    once you break the nut back it of till its a little over flush with the bolt and pound it out
  14. #14 Re: noob question about two bolts in the suspension..
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    the bolts are splinned so u can take the nut off without bolt spinning. after you get the nut off u pound them out make sure u dont mess up the threads, i use a brass hammer cus it wont damadge any threads
  15. #15 Re: noob question about two bolts in the suspension..
    Charles City, IA
    Oh, then yes I totally agree. I normally use my 3/8" tho.
  16. #16 Re: noob question about two bolts in the suspension..
    Feb 2010
    atlanta
    thanks for all the info guys... car will be lowered this weekend
  17. #17 Re: noob question about two bolts in the suspension..
    Aug 2008
    KCMO
    what springs are you using? as we can all see your using agx struts
  18. #18 Re: noob question about two bolts in the suspension..
    Donating Users Mikey's Avatar
    Apr 2009
    Virginia Beach
    It looks like the top bolt is not the oem bolt. If you hit that one you risk damaging the threads and may cross-thread the nut when you re-assemble
    Use a brass drift if you have one. Just don't go pounding any bolts. If you don't have a brass drift use a large centering punch.
  19. #19 Re: noob question about two bolts in the suspension..
    Quote Originally Posted by Mikey View Post
    Pic is from Geddy's how to thread for wheel hubs.
  1. Stupid NOOB Question
    By dbextreme in forum Forum Bugs/Suggestions
    Last Post: 04-15-2010, 07:17 PM
  2. noob question....
    By OhsoKleaN in forum Tires & Wheels
    Last Post: 02-08-2010, 02:32 PM
  3. noob question
    By 97grandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-24-2009, 06:45 PM
  4. Biggest noob question ever with rims
    By pillathwi in forum Tires & Wheels
    Last Post: 04-18-2009, 08:30 PM
  5. just another NOOB question about pcms...
    By NaturallySmashed in forum PCM Tuning
    Last Post: 03-24-2009, 11:47 AM
