Thread: Slotted rotors noisy?
Results 1 to 15 of 15
  1. #1 Re: Slotted rotors noisy?
    Well consider that the more you upgrade the front, the more you move the brake bias to the front.
    Theres only so much traction in the front and if you have too much brake force in the front compared to the rear then the fronts will lock up first.
    I'd just do the 12's and the stock calipers for now and see if you like that.
    But before that again, I'd try a higher performance pad first.
  2. #2 Re: Slotted rotors noisy?
    Apr 2009
    California
    Slotted rotors only make a notable whirring sound under heavy braking. With regular driving you'd be hard pressed to make out any sound whatsoever with the windows up.
  1. Noisy supercharger at air intake
    By Purple Plazma in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 09:46 AM
  2. Noisy Supercharger. Bad Coupler?
    By JoelW98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2009, 05:57 PM
  3. Where to get over sized slotted rotors?
    By boomboom in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 11:45 PM
  4. noisy flex
    Last Post: 04-11-2009, 01:22 AM
  5. Drilled/Slotted or both?
    By GP2003GT in forum Brakes/Suspension/Chassis
    Last Post: 04-20-2008, 12:43 PM
