Thread: i want to remove abs module..how?
Results 1 to 4 of 4
  1. #1 i want to remove abs module..how?
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    ive viewed pics of grand prixs that had their abs modules removed and master cylinders replaced..does anyone know what master cylynder and other parts id need to do this
  2. #2 Re: i want to remove abs..how?
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    just disconect the abs unit or pull tha fuse y do all that? when it disabbled wenever you disconnect anything to do with the abs
  3. #3 Re: i want to remove abs..how?
    Feb 2010
    somewhere cold
    for looks..i want the entire module gone so what i really need to know is what clyinder to replace with and what lines i need to modify to remove them from the abs module and put them inthe new master cylinder
  4. #4 Re: i want to remove abs module..how?
    Feb 2010
    somewhere cold
    ANYBODY? no ones got an answer...ive seen this on two different grand prixs just dont know if ill see them again
  1. How to remove oil pan
    By CheeseWithMyWHINEplz in forum General Tech Discussion
    Last Post: 07-01-2009, 01:54 PM
  2. Remove cat.
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2009, 02:43 PM
  3. Can't remove key
    By GrandPrixlbc in forum General Tech Discussion
    Last Post: 08-08-2008, 06:30 PM
  4. How Can I Remove This ?
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 04-23-2008, 01:18 PM
